Unable to Close Sunroof...
Old 03-20-2018, 08:42 PM
immacbignate's Avatar
Default Unable to Close Sunroof...
Hi, my name is Nathan and I am New to the Forums. I joined up because I might need some technical help. But wanted to intro myself.
I have a First Gen 2007 tC with literally 5,600K on the ODO that is Full Show. There literally is nothing not modified on my car, Excluding the Engine. lol
My Sunroof in my tC is no shutting anymore. It will move about an inch then start to grind then stop. I can go backwards to full open but I can't close it.
This is on an 07 tC that is Full Show so taking it to a dealership it out of the question.
Wanted to know if anyone knew how to remove it so I can just replace it?
______________
Last edited by MR_LUV; 03-26-2019 at 04:04 AM. Reason: Created Thread for New Member in Correct Forum
immacbignate is offline
Old 03-21-2018, 12:11 AM
Administrator
Administrator
MR_LUV's Avatar
I do not know if anyone here has a solution for you as far as experience in 'How to Replace your Sunroof'
Outside of a Dealership or a Automotive Repair Shop.
Your Best Bet is to try a
Sticky How To Advanced Search on Scion Life
If you haven't already, try Google, YouTube, Facebook, Reddit...
Moderator
MR_LUV is offline
Old 03-23-2018, 05:39 PM
Drew7011's Avatar
Nathan, I believe in another post you mention having to disconnect the battery for your car on a regular basis. If this is correct, you might be having issues with the window calibration. Any time the battery is disconnected the car has to be retaught how to open and close the sunroof, and the driver/passenger window. I believe if you disconnect your battery for about 5 minutes, and then close the sunroof and hold the close button down for 5 seconds after the roof has closed. Hopefully that fixes the issue. Good luck!
-Drew
Drew7011 is offline
Old 04-20-2018, 12:33 AM
Moderator
Moderator
alxm's Avatar
Nathan most likely the sliding mechanism, that pops up the wind deflector, needs to be re-lubricated as this is what causes it to bind and stop sliding forward. Until you can re-lubricate it, for the mean time. When closing the sunroof, with your hand through the opening. Manually pull down the wind deflector that pops up while at the same time closing the sunroof. This will bring down the side hinges/brackets that pop up the wind deflector and allow the sunroof to slide smoothly forward without obstruction. Be ready to remove your hand so that you don't hurt yourself and pinch it when its almost closed.
alxm is offline
crush02342002
369
12-13-2019 06:16 PM
NotAllBad
06-03-2008 04:14 AM
riccochetrabbit
15
07-21-2005 01:49 AM
Quick Reply: Unable to Close Sunroof...
