2006 Scion xA, low rpm
Old 07-23-2018, 09:16 PM
greyfox1592's Avatar
Default 2006 Scion xA, low rpm
So I've replaced IACV I've cleaned the throttle body, air filter isn't that old or dirty, yet sitting at a red light it will idle extremely low, like I'm talking almost at 0, won't shake or anything, won't stall, just chills at like 2 or 300 rpm, runs fine but if I'm going 25 or 30 and just take my foot of
the gas the rpm drops FAST, I'm thinking it may be an exhaust like or vacuum leak, or maybe my O2 sensors? Anyone with any advice I'd love to hear it, cause I'm at loss with this lol, like I said it runs and drives as good as I would expect a 4 cylinder, little sluggish from a complete stop,
but other than that it does everything I need it to do.
Last edited by MR_LUV; 07-26-2018 at 02:57 AM. Reason: Moved to Correct Forum by Administrator
greyfox1592 is offline
Old 07-25-2018, 11:47 PM
2stroked's Avatar
How many miles on it? Stick or automatic?
2stroked is offline
Old 07-26-2018, 12:11 AM
I'll have to check on the miles I'm at work right now but it's an automatic transmission, I change the oil every 5000 miles
Old 07-26-2018, 12:41 AM
175504 miles
Old 07-29-2018, 01:23 AM
2stroked's Avatar
What does the ATF (automatic transmission fluid) smell / taste like. Red and sweet is good. Brown and burned is bad.
2stroked is offline
Old 08-21-2018, 09:56 PM
Fluid wasn't burnt to much deff. Wasn't black , still had a red tint to it , changed fluid and filter anyway just to be sure, broke open old filter, had maybe 2 or 3 small metal shavings inside the filter, but from what I've seen that's normal, they wernt big either like the size of a newborns fingernail clippings or smaller, still idles low in drive at a full stop
jflowbeatz
05-14-2019 07:19 AM
annika
03-16-2015 06:36 PM
EATJ
02-06-2013 03:31 AM
Coolwaterz
11
12-17-2008 02:09 AM
vervesix
38
10-02-2006 05:03 AM
Quick Reply: 2006 Scion xA, low rpm
