Turn signal lites on door mirror kit of '06 xB?
Old 08-03-2018, 11:23 AM
Kerry's Avatar
Default Turn signal lites on door mirror kit of '06 xB?
Anyone know of a kit that would upgrade (replace or wire) my left and right door mirrors so that each would light when the turn signal was actuated? The buzzer volume for the directional is very low. The LED blinker lite in the dash could be 3x as bright. Sometimes I find myself having forgotten to turn off the blinker. For certain the next car I buy will have those lights on the mirrors—a must for us seniors.
Thanks, Kerry
2006 Scion xB
Kerry is offline
Old 08-03-2018, 07:45 PM
Super Moderator
SuperMod
MileHightC's Avatar
Like this...
Turn Signal Arrows
MileHightC is offline
Old 08-03-2018, 09:20 PM
Kerry's Avatar
Much thanks MileHightc, I'll try it.
Kerry
Kerry is offline
Old 08-16-2018, 03:09 AM
Kerry's Avatar
Got the directional arrow for the driver side working nicely.
The original putty-glue that glued the glass mirror to the plastic housing inside the mirror housing was still flexible but there's not enough to reuse it. Got suggestion as to an adhesive that can be heated to remove the mirror if necessary?
Thanks, Kerry
'06 Scion xB
I'm very pleased with the quality and price of these parts:
Burco 5201 Passenger Side Replacement Mirror Glass for 2004-2006 Scion xB Burco 5201 Passenger Side Replacement Mirror Glass for 2004-2006 Scion xB
Sold by:
 Overdrive Brands Overdrive Brands
via Amazon. (It has the "Objects look closer ..." etching"
$15.05
Burco 4101 Flat Driver Side Replacement Mirror Glass for 2004-2006 Scion xB (2004, 2005, 2006) Burco 4101 Flat Driver Side Replacement Mirror Glass for 2004-2006 Scion xB (2004, 2005, 2006)
Sold by:
via Amazon
$15.58
Universal Fit Ultra Slim Amber or Red 14-SMD LED Arrows for Car Side Mirror Turn Signal [Color:Amber] (Required nibbling away some of the plastic in the mirror housing to ensure it laid flat. Brightness of the LEDs is perfect).
http://store.ijdmtoy.com/SearchResults.asp?Search=35-331&submit=$9.99
Wire Connectors - TYUMEN 12pcs 2 Pin 2 Way Low Voltage Universal Compact Wire T Tap Connectors, No Wire-Stripping Required, Toolless Wire Connectors, Wire Connectors - TYUMEN 12pcs 2 Pin 2 Way Low Voltage Universal Compact Wire T Tap Connectors, No Wire-Stripping Required, Toolless Wire Connectors,
(Ran wire from LED directional arrows assembly affixed to the mirror housing to the driver side amber light on the fender. The connectors worked perfectly the very first time.)
Sold by:
 TyumenDirect TyumenDirect
via Amazon
$11.96
Kerry is offline
Old 08-16-2018, 01:38 PM
Super Moderator
SuperMod
MileHightC's Avatar
What about a decent silicone adhesive? If you ever needed to remove it you could just use the fishing line/dental floss trick...
Old 08-16-2018, 09:34 PM
Kerry's Avatar
Thanks MileHightC. I tried 100% clear silicone and the mirror kept sliding down. I wasn't certain that even if I taped the mirror to its correct position that it wouldn't slide overnight.
Now I don't know how to remove the silicone from the mirror housing so that I can try another adhesive. I had soaked the housing in gasoline (which worked great) to get the original adhesive off but now that the LED assembly is securely affixed to the mirror housing its going to be tricky getting the sticky silicone completely removed so that another adhesive will stick. Going to town to get another adhesive.
I sure do like the reminding flashing amber directional arrows.
Kerry is offline
carid
Scion tC 1G Aero & Exterior
10-01-2014 11:46 AM
surfcitylocal
03-13-2014 02:43 AM
ShawnBenton
11-28-2012 10:10 AM
DJ_FroZone
12-06-2011 05:52 PM
Vang2k
12-07-2007 04:30 AM
Quick Reply: Turn signal lites on door mirror kit of '06 xB?
