06 xB No Start..
Old 10-21-2018, 01:15 AM
Pwlyt's Avatar
Question 06 xB No Start..
Went out the other day to start my 06 xB and got nothing. No clicks, no warning lights, gear shift stuck in park. Charged battery...Nothing.
Replaced battery, started right up. Went out this morning and it’s the same original dead duck. Nothing.
Dead short somewhere?
Last edited by MR_LUV; 10-21-2018 at 06:34 PM. Reason: Moved to Correct Forum by Administrator
Pwlyt is offline
Old 10-23-2018, 11:03 PM
RichBinAZ's Avatar
Sounds like a short somewhere, although it should have popped a fuse...
Was there a spark when you connected the 2nd terminal to the new battery?
Is the interior light stuck on?
When you put the charger on it, do any lights come on? How much current is it pulling
RichBinAZ is offline
Old 10-27-2018, 04:05 PM
Super Moderator
SuperMod
MileHightC's Avatar
You can take it to an auto parts store and most of them will do a charging system test for you...if it died overnight I would say you've got a pretty significant draw coming from somewhere that you're going to have to chase down.
Will the new battery take a charge?
Any other info on the car...aftermarket alarm, other additions to the electrical system, etc. You can put a meter on it and see if it's pulling a charge even when the cars off...that'll be what you need to find and you can narrow it down by pulling one fuse at a time to see which one makes it go away. Chasing electrical is never fun.
MileHightC is offline
Old 10-31-2018, 04:02 PM
Big_Jim's Avatar
Did you drive it after replacing the battery and starting it up?
I'd take the alternator to get tested at your local parts shop.
Big_Jim is offline
Old 11-03-2018, 11:18 AM
RichBinAZ's Avatar
Doing the quote may help the OP find it
As Big Jim says, your alternator may have failed if none of the other items are the culprit
If you can get the engine started, you should be able to measure 14V at the battery with a working alternator. If it's just 12.x Volts, then the alternator is not charging. Check at stays at 14V by reving the engine to 2-3000 rpm.
Something I didn't know existed were alternator rebuild kits ___https://www.maniacelectricmotors.com/nsearch.html?#search/q=scion%20xb%20&sortby=rel&page=1&size=15&storeid=yhst-44365514171686/1___
A lot of places sell these kits and if the stator and rotors are fine, you can just replace the regulator for a lot less than a new/rebuilt alternator
boostHerWay
02-22-2018 08:53 AM
joey3002
12-12-2012 09:24 PM
olecram
Scion tC 1G ICE & Interior
11-27-2012 05:38 AM
1vicissitude
02-15-2009 06:15 AM
swartzautoman
08-05-2007 07:24 PM
Quick Reply: 06 xB No Start..
