Power Loss - Issues with Throttle Response
Old 03-22-2019, 09:40 PM
Steven4x4's Avatar
Default Power Loss - Issues with Throttle Response
Hello,
I have a 06 Scion xA Manual Transmission.
I'm having issues with throttle response when I need to go fast.
If I'm just cruising around at low speeds I do not experience any issues. (Usually in the lower RPM's going up).
However, when I need to get going quickly, when I shift into the next gear and have the gas pedal floored...
The car revs up high, but the power is no longer there, it takes a second for it to start moving.
I've changed the spark plugs, ignition coils, fuel pump, fuel filter, fuel regulator and have cleaned the MAF sensor and Air Filter and have ran SeaFoam through it.
The fuel injectors seem fine.
My cousin mentioned the clutch might be going out, but I don't believe that to be true as I'm not experiencing any other issues related to the clutch or shifting for that matter.
No check engine or error codes.
Any thoughts or suggestions?
Steven4x4 is offline
Old 03-23-2019, 11:13 AM
2stroked's Avatar
Sounds like your clutch is slipping. When this happens, do you smell anything awful? A slipping clutch smells just like over-heated brakes.
2stroked is offline
Old 03-23-2019, 11:29 PM
Steven4x4's Avatar
No - Nothing smells.
However, if we take the shifting out of the equation.
Say, I'm in 3rd gear at 2.5-3 RPMs, if I try to floor it, the same thing happens, high rev, then a delayed throttle response.
So, I don't think that shifting is really even part of the problem anymore.
Old 03-24-2019, 11:39 AM
2stroked's Avatar
There's only two ways RPMs go up quickly in a standard transmission with the clutch engaged. The desired way is the car accelerates as fast as the gearing will allow. The other way is the clutch slips. From what you've described, you have the latter. Take it to a competent shop and have them drive it before you waste any more money throwing parts at it that it doesn't need.
2stroked is offline
Old 03-24-2019, 02:33 PM
Super Moderator
SuperMod
MileHightC's Avatar
Excellent advice and I'd agree that you have a slipping clutch...
MileHightC is offline
Old 03-25-2019, 05:29 PM
Steven4x4's Avatar
Thanks for all the feedback.
I'm not familiar with the term "Component Shop". Is there another name for it?
Old 03-25-2019, 07:30 PM
2stroked's Avatar
Competent shop. That's a shop that knows what they're doing.
2stroked is offline
Old 03-25-2019, 07:42 PM
Steven4x4's Avatar
Oops - That's embarrassing. Thanks for the correction.
Thanks for your help!
Old 03-25-2019, 09:55 PM
2stroked's Avatar
No problem. Let us know what you find.
2stroked is offline
Old 05-27-2019, 04:39 AM
michael73's Avatar
Clutch - nothing else.
michael73 is offline
andrey
16
08-08-2014 05:44 PM
uskrewed
Scion xD Drivetrain & Power
36
08-28-2009 12:39 AM
Leemartini81
9
05-11-2008 08:06 PM
T-Scion-C
10
03-02-2007 07:00 PM
zizi
09-12-2004 03:20 AM
Quick Reply: Power Loss - Issues with Throttle Response
