Need help car won't start.....new battery/alternator
Old 03-25-2019, 11:34 PM
Junglejim's Avatar
Default Need help car won't start.....new battery/alternator
I have a 2011 tC new battery, new alternator, headlights work, all lights on dash on. Door locks don't work, radio won't come on, car won't even turn over. Have continuity to starter.
When I pulled the old alternator, I forgot to disconnect battery, the wire from alternator hit dipstick tube and sparked.
I checked voltage from negative post to alternator wire (17.89). I have also checked all smaller fuses under hood and dash.
Can someone assist with next step?
Thanks in advance.
Sticky How To Advanced Search SL (Scion Life)
Last edited by MR_LUV; 03-26-2019 at 12:29 AM. Reason: Moved to Correct Forum by Administrator
Junglejim is offline
Old 03-26-2019, 02:47 AM
62Fender's Avatar
Did you check the fusible link?
62Fender is offline
Old 03-26-2019, 03:04 AM
Junglejim's Avatar
Yes....looked only nothing burnt. Is there a way to test with meter without removing entire fuse box?
Old 03-26-2019, 01:32 PM
62Fender's Avatar
Was hoping the burnt point might be visible. Sorry, I don't know how to test it in place.
A search for "fusible link" returned 45 threads. One or more may mimic your symptom (or combination of) ie, no door locks/ no radio/ no start.
62Fender is offline
JoeyBishop
09-28-2022 01:34 AM
Xtrs87x
10-19-2012 03:05 AM
stan2187
05-30-2012 11:43 PM
Ghosty44
Scion tC 1G ICE & Interior
05-10-2011 05:51 AM
Quick Reply: Need help car won't start.....new battery/alternator
