Scion xD Drivetrain & Power Engine and transmission discussions...
2008 xD MAF Fault..Poor running..
Old 05-20-2019, 11:22 PM
shagy2303's Avatar
Default 2008 xD MAF Fault..Poor running..
2008 xD has a MAF fault and Air Temp Sensor fault, had it scanned. Have tried 2 separate MAF sensors with no luck. From what I understand both sensors are in the same module.
Rough idle and cannot go above 2000 RPMs with out it cutting out.
Any help would be a god send as this is my "GOOD" car.
_______
shagy2303 is offline
Old 05-21-2019, 04:53 AM
Administrator
Administrator
MR_LUV's Avatar
Rough idle and cannot go above 2000 RPMs with out it cutting out. Any help would be a god send as this is my "GOOD" car.
It would Help if you were to Provide any CEL Codes you are getting:
How to Turn Off The CEL..How To Diagnose Your Check Engine Light For Free
MR_LUV is offline
Old 05-21-2019, 04:56 AM
shagy2303's Avatar
To be honest I would have to get it scanned again for the numbers but one was maf failure and the other was the air temps sensor temp failure
Old 05-21-2019, 07:19 AM
Administrator
Administrator
MR_LUV's Avatar
To be honest I would have to get it scanned again for the numbers but one was MAF failure and the other was the Air Temps Sensor Temp failure
There is More than One Possible Causes for the MAF Fault and the Air Temp Sensor Fault.
Once you Post the CEL Codes, then we can Narrow down the Suspects.
That's Why the Numbers (CEL Codes) are Important.
__________
MR_LUV is offline
EWXa
03-26-2014 05:09 PM
ScionFred
02-26-2010 06:09 AM
Diluvium
09-04-2008 12:04 AM
exige
12
11-10-2007 03:04 AM
lowtrefin
06-13-2006 10:56 AM
Quick Reply: 2008 xD MAF Fault..Poor running..
