DIY tC2 Independent Fog Light Mod Thread 2.0
4 Attachment(s)
DISCLAIMER: MOD AT YOUR OWN RISK - I am not responsible for you doing this incorrectly and damaging your car and/or yourself. This is what worked for me and if it doesn't for you, oh well.
Since the pictures on the old thread mysteriously disappeared and a few people still need this info, I figured I'd post up a 2.0 version of the thread. So let's get crackin - NOTE - This is meant to work with fog lights that are installed from the factory/dealer and may or may not work with aftermarket fog light kits you install yourself. Tools you'll need - 10mm socket - Wire strippers - About 3ft of wire (14g recommended) Not necessary, but good to have - - Wire crimpers - Wire butt connectors - Female spade connectors - Wire taps - Electrical tape First off, get in the car and remove your radio bezel by pulling on the edges until it pops off, unplug the plug behind the clock and set the panel to the side. Next remove the radio by unscrewing the 4 10mm bolts on all 4 corners of the radio. Pull it out, unplug all connectors and set it aside. Under where the radio was There is a bracket holding the relay for the fog lights, unscrew the 10mm bolt holding it in place and pull it up so you can access the wires. Attachment 121565 Sorry about the cluttery wiring but you get the idea. Locate the 18g RED wire and cut it with adequate room to strip. Strip and extend the part of the wire the is coming from the relay. The other half can be left there. Attachment 121566 Run the wire under the dash so it can reach to the fuse box under the driver's side of the dash. Remove the panel covering the fuse box by pulling on any side until it pops off. Depending on how you want them to work, you will have to locate a wire for power. If you want them to turn on with the parking lights, locate the 18g LIGHT GREEN wire coming out of the white large plug from the fuse box, tap into this wire and connect the wire you ran earlier to send power to the fog lights via your parking lights. Attachment 121567 If you want them to turn on with ignition (as in they will turn on any time the car is on so long the button is activated), locate the 14g GREY wire in the loom directly in front. (You may have to cut through tape to access it), tap into this wire and connect the wire you ran earlier to send power to the fog lights via ignition. Attachment 121568 Everything is now connected so you can put back all panels and your fog lights are now independent! I hope this helped! |
AWESOME! STICK'D :)
Did the light green wire version "fogs on with parking lights" Here's my problem.. Did everything right but now my fogs do not work also when I turn my headlights on the lights in my head unit fade completely out and as soon as I turn my headlights off the head unit lights come back on lmao help..
This is what happened last time I did it. The heat/ac knobs would not light up. After a few days it started to smell like burned plastic. The wires were melting.
Why not just run your fog wiring independently from the lights. Control them with a separate switch
Credit to: SoKrispy https://www.scionlife.com/forums/mem...ring-20803.jpg |
Originally Posted by Xversa
(Post 4163465)
IMHO Its a lot easer, and SAFER to run separate wiring and not run the risk of damaging your car's electrical system.
This will also work with factory installed lights. You just bypass the factory wiring. |
(Post 4163746)
(Post 4163465)
Hi everyone. I bought an aftermarket fog light for my 2011 tC and wanted to know if there was a way to use the original fog harness and hook it up to my fog lamps. I searched for 2 months for an answer and found nada.
I was hoping someone could help figure out how to manage this wiring mess. Thank you kindly. _____________ |
you are the man! been looking for the parking light wiring for days now.
Originally Posted by BWizzard
(Post 4164911)
hi everyone. i bought an aftermarket fog light for my 2011 tc and wanted to know if there was a way to use the original fog harness and hook it up to my fog lamps. i searched for 2 months for an answer and found nada.
i was hoping someone could help figure out how to manage this wiring mess. thank you kindly |
okay I tired the green wire and I think I used there wrong one. There is about 5 different green wires with the grey dots coming off of the wiring. So I just used the grey one.
Originally Posted by jaspercanda
(Post 4164943)
No way. The plugs wont fit unless its OEM.
big fat grey one coming out of the 2nd (middle) connector.
Originally Posted by TCnewguy
(Post 4165042)
https://app.box.com/s/6g9e58exjnkmqoeeyew06xsl6o6twpq1
https://app.box.com/s/ngzuex8tirlzx9fs405q0h9ujgb104c7 almost there . i did some testing after hooking up to the ignition aqnd completingg all the wirring and all is GOOD! im wso happy you guys could help with this. even thought i was stupid enough to ask questions that were answered in the original post.... :( :gun: i will wait for warmer temperatures to go uner and finish the instal. |
There is a 4-pin plug behind the panel with the controls for the side mirrors. It will probably be taped to a bundle of wires. This plug is for the factory fog light switch. The wires are tan, brown, blue, and white/black. The brown wire shows 12 volts when the parking or headlights are on. If you have an aftermarket fog light switch, this is unused, and will serve the same purpose as the light green parking light wire, and that brown wire is right where you need it to be.
