How to remove Steering Wheel plastic and repaint (with pics)
yea as long as you take your time shake your paint and clear coat and wetsand after everything is dry it does
i ended up having to redo the bottom piece because i tryed to rush it and messed it up
try to wet sand it before you completely redo it get some 1000 gritt and try that if you cant get anywhere with that try the next step down i wouldnt go any less then 400 gritt but thats just me you risk pulling paint on the edges
idk i think i may do it like my emblem and an fyi this is on my old OG 2011 tc i did things alittle different with my new one check my build plus ill post pics of my front emblem and let you see what it looks like i may do the same with my horns
sorry it took so long to reply the best way to remove paint is to either use paint thinner let it soak (this is really only good if its within the first 12 hours) but to get rid of dry paint the easiest way it to wet sand with 320 grit sand paper till smooth then switch to a finner paper like 800 or 1000 then repaint and do just like you would before
