tC Tech and DIY Info for the Scion tC
Airbag Light Resistor Fix (Aftermarket Seats)
Old Sep 16, 2008 | 10:01 AM
  #41
2006xtC's Avatar
Ahhh... yes, I fail. Thanks for solution jurassic1, I think I should be able to handle that.
Old Sep 26, 2008 | 05:41 AM
  #42
fujita_TC's Avatar
I still can't figure out mine I don't have the yellow plug. And I noticed that the passenger and driver plugs are different now I niticed that I have a plug where there's nothing to plug into or the other way around nuthing to plug in don't remember.
Old Sep 26, 2008 | 02:18 PM
  #43
jurassic1's Avatar
Oh we both have '07. Good. Where is your "mystery" plug located? Driver's or passenger's?
If you don't have the seat airbags, the driver's seat will have the position sensor and the seatbelt sensor plugs. For the passenger seat, it will have the seatbelt sensor plug and the four (4) passenger occupant sensors (4 plugs that connect onto one module under the seat, which then connects via one plug/harness towards the srs module).
Old Nov 24, 2008 | 10:42 PM
  #44
iocca's Avatar
since i am a mpron when it comes to this kind of stuff, and there aren't any pictures, ill post my own and ask questions, i couldn't find 5 ohm 1/2w resistors, so i got 10 ohm 1/2 watts. now, which way do i need to do them, or does it not matter (note the stripes going different directions on the first one)?
or
Old Nov 25, 2008 | 03:56 AM
  #45
darrem's Avatar
I tired to make it work but I failed...I'm just going to find way a to seal this sensor from another tC something like that! maybe a new tC or wrecked one. I was also told that even with light the air can still deploy. So I'm not to worried about it.
____________________________
new york city limo service
Old Jan 27, 2009 | 08:46 AM
  #46
BlkTC's Avatar
sticky please...
Old Jan 28, 2009 | 03:17 AM
  #47
dodaddy's Avatar
My airbag light went away when I made the magnet stick to my new seat bracket, i didnt modify any plugs
Old Feb 15, 2009 | 04:24 AM
  #48
Ro_Ja's Avatar
Sparknotes:
1. Getting a bucket seat for driver's side only. The passenger seat will NOT be replaced.
2. Side and leg bolsters are too large for use of stock seat belt system.
3. Will get a Takata harness.
Now here's the problem. I've done a lot of reading, but either it wasn't clear to me or pictures were missing, but I want to know EXACTLY how to make sure the airbags work when I replace the drivers seat ONLY. If I'm in an accident, I want to be sure they properly deploy. And I do have the SRS airbag package in my 07 tC if that makes any difference. Thanks in advance!
Old Feb 15, 2009 | 04:42 AM
  #49
SF2K4's Avatar
Hey guys... miss me?
I don't have the pics anymore but I'll try and describe this so it makes sense... if it doesn't let me know and I'll try to get pics again...
1. Get 2 10 ohm resistors.
2. Put them parallel to eachother (on top of eachother with the leads running in the same direction).
3. Take one of the resistors and wrap it's left lead around the other's left lead and repeat with the right side.
4. Bend the leads from the non-wrapped resistor into a U shape and insert into the yellow airbag slot (after you removed the part that was attached to the seat).
Does that make sense?
Old Feb 15, 2009 | 04:47 AM
  #50
Ro_Ja's Avatar
Thanks. Could you post the pictures? It would be extremely helpful if possible. I definitely don't want to mess this up.
Old Mar 24, 2009 | 06:23 PM
  #51
DonNguyen's Avatar
bump for pics
Old Apr 8, 2009 | 01:42 PM
  #52
davedavetC's Avatar
i wonder if something similar to this would work for the steering wheel airbag
Old Apr 8, 2009 | 01:44 PM
  #53
CarbonXe's Avatar
I'll try to take pictures when I install my seats.
Old Jun 9, 2009 | 03:07 AM
  #54
SilverCFtC's Avatar
Has anyone found a way to make the 4 passenger side sensors work with aftermarket seats on an 07? Or a good way to override them? I pulled all four out of the OEM Seat. They appear to be strain gauges, so I threw a bunch of zip ties around them, but that's not doing the trick. I'm gonna go PM TcPete.....
-Sean
Old Jun 16, 2009 | 09:11 PM
  #55
CSOCSO's Avatar
bump for pics.
Old Jun 17, 2009 | 02:55 PM
  #56
HKSpeed's Avatar
x2
Old Jun 25, 2009 | 11:59 PM
  #57
CSOCSO's Avatar
bump bump
Old Jun 26, 2009 | 04:07 AM
  #58
BZinn1's Avatar
-Sean
gotta squeeze them just a bit with chanel lock pliers to close the circuit and then run 3 large zip ties around them,then the resistor in the yellow plug......your seatbelt will buzz when you start the car cause it thinks there is a person in the seat with no belt on......it can be silenced using the easteregg to turn it off......but every time you unhook battery it will come back to stock settign.........
Old Jul 3, 2009 | 08:06 PM
  #59
goodguy889's Avatar
does anyone know the ohms for the steering wheel airbags?
Old Jul 5, 2009 | 12:31 AM
  #60
ack154's Avatar
I was going to add this to Tech... but still no pics?
