tC Tech and DIY Info for the Scion tC
Chassis Bolts Maintenance
Old 12-29-2008, 10:10 PM
  #61
HECKZ42's Avatar
thanks for this. ill look into mines im at 50k n nvr checked this at all.
HECKZ42 is offline
Old 01-20-2009, 06:57 PM
  #62
Mong1126's Avatar
i know this is a nub question, wheres all the chassis bolts located at? can anyone give me a full detail of their location?
Thanks in advance.
Mong1126 is offline
Old 01-20-2009, 08:45 PM
  #63
sciontc_mich's Avatar
^^ check the first page, links are there with diagrams.
sciontc_mich is offline
Old 01-21-2009, 06:33 AM
  #64
Mong1126's Avatar
thats a whole lot of f'ing bolts!!
Mong1126 is offline
Old 02-17-2009, 02:25 AM
  #65
davedavetC's Avatar
um i had 90k on my tC when i signed papers for the wrx and i never had any problems...
davedavetC is offline
Old 02-18-2009, 06:11 AM
  #66
scionkei's Avatar
wouldn't this be some sort of potentially huge/severe safety issue for the Tc?
scionkei is offline
Old 02-18-2009, 07:35 AM
  #67
cooldrive003's Avatar
thanks for your info
cooldrive003 is offline
Old 02-18-2009, 01:39 PM
  #68
JOEinSD's Avatar
Will be checking the very next chance I get to. THANKS!
JOEinSD is offline
Old 02-18-2009, 08:13 PM
  #69
you're saying liability for Toyota? no, because they have it listed as part of the maintenance in the book. So they have already indicated it needs to be looked at. Just because the dealers ignore it, doesn't change the reality it should be looked at.
also JOEinSD and cooldrive003, you're welcome!!
Old 03-01-2009, 05:05 AM
  #70
AdmirN's Avatar
Oki so after i get my 2nd free oil change and 10,000 mile maintenance. Is the dealer suppose to do the addition maintenance or was i suppose to ask them 2 do it because thats where they would check all bolts on the chassis... Is it possible for me to still go up there and ask them 2 check it for me cuz this weather sucks...
AdmirN is offline
Old 03-01-2009, 05:09 AM
  #71
Mouse's Avatar
dude..^^ I would certainly go back in and have them throw it on a lift to check. they know this is a safety thing and should gladly do it free of charge.
Mouse is offline
Old 03-01-2009, 05:12 AM
  #72
AdmirN's Avatar
I hope so, ill be going Monday and checkin it out.....
AdmirN is offline
Old 03-01-2009, 05:19 AM
  #73
Mouse's Avatar
if it is safety related... trust me.... they will do it for you no charge.
Mouse is offline
Old 04-27-2009, 10:35 AM
  #74
kuo34's Avatar
I found the nuts to my steering rack casing were loose and one was missing. I'm not sure how long they've been like that. The nuts grip the subframe from the bottom so it's recommend that you torque them from above, though you can sneak a wrench in on the passenger side bolts and hold the bolts from turning. On the driver's side you'll need a ratchet with an extension and a friend to put it down through the engine compartment or wheel well.
Or you can drop the subframe and torque the bolts from the top like the service manual says.
*shrug* maybe you won't find anything when you look, but it's still worth a look.
kuo34 is offline
Old 04-28-2009, 01:43 AM
  #75
Bojan087's Avatar
well i take my car to the dealer since i have my free oil changes but my question is when they do the next one, whats all that i should tell them to check? cuz if i tell them "can you check the bolts to my suspension and steering wheel" they might be confused since im srue there are many. is there a more specific name for all the places that need tightened?
Bojan087 is offline
Old 04-28-2009, 02:46 AM
  #76
^^ i think that most dealers won't take the time to check them all because they don't want to be bothered. Lazy, I call that! No real name other than "chassis bolts/nuts" like the maintenance manual describes them as. I doubt a dealer would take a torque wrench to each bolt and even if they did, they'd charge you $$$ for it. The other thing they could do is see if all of them are tight/not loose.
Old 04-28-2009, 03:52 AM
  #77
kuo34's Avatar
It doesn't take long to jack the car up, plop it on jack stands, and wriggle under with a torque wrench. Sure it'll be dirty and sweaty, but what's the price of peace of mind?
kuo34 is offline
Old 11-18-2009, 05:12 PM
  #78
Jasper Ash's Avatar
Thanks for the heads up! I wonder if anyone has ever gotten into an accident because of this...
Jasper Ash is offline
Old 11-19-2009, 12:39 AM
  #79
Mouse's Avatar
I would seriously doubt it due to that being the root cause alone.
Back on older cars maybe....but with Uni-Body construction that's no longer the case.
Mouse is offline
Old 11-19-2009, 03:06 AM
  #80
^^ actually the problem is that the nuts are not self-locking. It's not about unibody or not. That is why it's advised to check the torque of the nuts. Which means they can loosen themselves and possibly come loose. It's theoretical that an accident COULD happen but I think the driver would have to be really not paying attention to the car, if those bolts were that loose.
Quick Reply: Chassis Bolts Maintenance
