DIY Clutch & Flywheel install for Scion tC
#81
I just did my clutch honestly you have to drop the whole tranny. You really want to because 1. You can replace the throwout bearing 2. Pull the fork off and clean and grease that fork pivot point and grease the two points at the end of fork where you see the wear from throwout bearing. 3. Clean the shaft splines the fsm says to grease the shaft I just greased the clutch splines so it doesn't get stuck to the tranny splines. If you decide to grease use a very very light coat of molly grease and remove excess grease. 4. clean the shaft sleeve with brake cleaner (where the throwout bearing rides on) then grease with a molly grease this has to be a very light coat or else it will collect at the end of the sleeve trust me on that lol. Make sure you clean the inner race grease and regrease with same grease used on sleeve. Just slide the bearing back and forth and wipe whatever collects at the end then install you'll have the smoothest clutch engagement ever. Don't forget to clean and grease the slave cylinder fork pivot point with lithium grease
#84
Hello,
I bought my wife an '05 TC manual with 93k on it and the clutch is on it's way out. Was wondering if there is a shopping list of the parts i need to get?
OEM or aftermarket (normal daily driver, no turbos here)?
I saw the Exedy clutch kit on Amazon and Ebay for about $140
thank you for the help.
#85
Hello,
#86
Other than tools, a clutch kit will have everything (ie. Clutch disc, pressure plate, throw out bearing, alignment tool). I like Exedy products and recently put an OEM one in my tC that had an Exedy Cerametalic Stage II. Just cross reference the clutch kit product number on Exedy's website because I've found from searching myself, Amazon/eBay sometimes sells the incorrect kit. The product number is TYK1506 for '04-'10.
Thanks!
#87
Overall if I had to do it over again, I'd consider going the same route or try the ACT Street clutch. By the way, I just swapped it for the OEM Exedy because I replaced my clutch master and slave cylinders last season but had problems arise that were different enough to prompt me to buy a replacement just in case. Well when I took the Cerametalic out, it looked pretty good still.
#88
Great thread follwed it worked great but now my car wont start it feels like the clutch isnt engaging all the way i bleed the lines replaced the starter and battery and checked all of my wires all it dose is click it is also a new slave cylinder idk what it could be!
#90
#92
bolts again😞
C11st I would like to thank those that helped me with my 11st question. 2Nd can anyone tell me which bolts hook the trans 5so to the engine. I hope I don't need more answers on this. I did but a set of repair manuals but not yet here.
#93
AlternativeFuelsNow
9
05-26-2005 06:52 PM
