tC Tech and DIY Info for the Scion tC
E-Manage Blue / Ultimate Anti-Stall Programming
Old 08-11-2009, 04:58 PM
Scionetics
KAD
paul_dezod's Avatar
Default E-Manage Blue / Ultimate Anti-Stall Programming
For those whom use these forms of engine management and have reported a stall when letting off of the throttle or putting the car in neutral and coasting; I will show you how to program your anti-stall setting to work flawlessly on your E-manage or Ultimate.
For E-manage Blue owners:
Support tool is needed to perform this!!!
  1. Connect support tool to E-manage
  2. Click Settings>Parameter Settings
  3. Check the box next to Anti-Engine Stall then click Confirm
  4. Click on the "ES" or Anti Engine Stall from the drop Down Menu at the top tool bar.
  5. Click Real Time Data Display
  6. Start the car and let idle
  7. Take note of the "Airflow Meter Output" voltage.
  8. Take that voltage output and add a small buffer of 5% to it.
  9. Take that voltage and input it into the "Clamp" row in the Anti Engine Stall Setting box across all RPM break points
  10. Change the TP% in the Anti Engine Stall window to 3%.
  11. Change time to 3 seconds or 5 seconds and you are done!
For E-manage Ultimate owners:
  2. Click on the little car on top tool bar
  3. Go to the "Map Select" tab and check the box for Anti Engine Stall, click apply then ok.
  4. Double click on Anti Engine Stall Setting on the left tree
  5. Hold "ctrl" on your keyboard and "t"
Brought to you by the Dezod Motorsports team!
paul_dezod is offline
Old 08-11-2009, 05:03 PM
Scionetics
KAD
paul_dezod's Avatar
possible sticky?
Old 08-11-2009, 05:28 PM
SoFloTC's Avatar
Sticky!! Thanks Paul, Ill try this out.
SoFloTC is offline
Old 08-11-2009, 05:31 PM
mattTc's Avatar
Paul... This is a prime example of why I love you. I've never bought anything from guys but next part I need I'm deff getting through you
Possibility of getting a DIY on basic tuning for emanage or even 2 step launch?
mattTc is offline
Old 08-11-2009, 05:34 PM
Scionetics
KAD
paul_dezod's Avatar
You're welcome Matt.
Tuning is a lot more complex and harder to denote through words. Plus there are many different tuning beliefs and schools of thought. Each person may tune the same differently.
Old 08-11-2009, 05:48 PM
ROCKET77's Avatar
Thanks Paul,
ROCKET77 is offline
Old 08-11-2009, 05:57 PM
gingles's Avatar
very nice
gingles is offline
Old 08-11-2009, 06:04 PM
mattTc's Avatar
alright, i gotcha paul.
any chance of how to set up 2 step launch?
mattTc is offline
Old 08-11-2009, 10:28 PM
crush02342002's Avatar
nice paul...even though i dont have the e-manage its good to have info out there..good job!!!!
crush02342002 is offline
Old 08-11-2009, 10:37 PM
m6ar2cel6oTC's Avatar
anyone try it yet?
m6ar2cel6oTC is offline
Old 08-12-2009, 01:39 AM
cessblood's Avatar
Nice write up Paul.
cessblood is offline
Old 08-12-2009, 02:32 AM
I vote sticky
Old 09-13-2009, 06:20 PM
tc1003's Avatar
Default Thank you
This is gold to a new guy like myself so #1 thank you.
Could you tell me the diffrence on this setting:
Not sure what one I should use?
tc1003 is offline
Old 09-13-2009, 06:22 PM
tc1003's Avatar
Originally Posted by m6ar2cel6oTC
anyone try it yet?
Im about to just need to ask one question about the 3-5 seconds.
tc1003 is offline
Old 09-13-2009, 07:57 PM
tc1003's Avatar
Did it using 3 seconds and no more stalling yet. Stalled 3 times this morning before I did this so looking good. Thanks again Paul
tc1003 is offline
Old 09-13-2009, 08:51 PM
yellowxhoodie's Avatar
stickied!
yellowxhoodie is offline
Old 09-13-2009, 10:02 PM
Ronin Scion
Ace83's Avatar
nice.. still have some love left for the emangle lol
Ace83 is offline
Old 09-14-2009, 02:03 PM
Scionetics
KAD
paul_dezod's Avatar
stickied!
Thanks!
Sweet! Glad I could help!
Old 09-14-2009, 06:20 PM
ValenciaS's Avatar
thanks paul , Dezod FTW
ValenciaS is offline
Old 09-16-2009, 06:34 PM
Scionetics
KAD
paul_dezod's Avatar
You're welcome
Quick Reply: E-Manage Blue / Ultimate Anti-Stall Programming
