tC Tech and DIY Info for the Scion tC
Header Install (DC Sports)
Old 05-27-2013, 08:16 PM
  #361
VolcomJonny's Avatar
Originally Posted by JOHNNYZX10R
Thanks for write up it really helped alot i currently installed a set of Alphawerks header with tsudo S pipe and Tsudo midpipe and a HKS axleback (sounds great) . I also did the Anti Foul trick with the 18mm 40002 product recomended from autozone but as you can see in the picture the O2 sensor is extremely close to the side and im afraid if going to brake. Any suggestions
Well that part of the chassis doesn't flex much. You should be fine. You can probably get a flex bracket for the under car it bolts right under and minimizes flexing and goves you a bit more stability. It also depends if you've upgraded your suspension and how much dampening you've adjusted. Look into it, it's the flex mount from Tanabe.
VolcomJonny is offline
Old 05-27-2013, 08:43 PM
  #362
JOHNNYZX10R's Avatar
I have teins s springs and energy suspension mount inserts, they told me they make angle anti fouls but im not sure where to look
JOHNNYZX10R is offline
Old 05-27-2013, 09:09 PM
  #363
I believe the fouler mod by Weapon R is an L shape angle but you'd be paying way too much for that. They're about $50. I mean these from autozone are like a buck each.
Old 05-27-2013, 09:46 PM
  #364
^^^ I have the ones from auto zone but since my spipe is a little thicker then once everything is install it rubs on the O2 . L shape might be my solution or re-do hole but I dont want that
Old 05-27-2013, 10:10 PM
  #365
Yeah just do some research on price and availability man. You'll be fine. But it won't give you a CEL?
Old 05-27-2013, 10:51 PM
  #366
itzallgood707's Avatar
Hey JOHNNY, can you post a video of your exhaust setup?
Sent from my SGH-T989 using Tapatalk 2
itzallgood707 is offline
Old 05-28-2013, 04:59 AM
  #367
Who me?
Old 05-28-2013, 05:00 AM
  #368
Sorry, no. I meant JOHNNYZX10R
Sent from my SGH-T989 using Tapatalk 4 Beta
Old 05-28-2013, 12:39 PM
  #369
Don't have one yet but soon i will my used tsudo midpipe came with another resonator that was install but i order a Vibrant ultra quite resonator . When i install that one i will post up video
Old 07-05-2013, 05:44 AM
  #370
KHalls_tC's Avatar
What happens to the bracket?
KHalls_tC is offline
Old 11-15-2013, 09:41 AM
  #371
Vladislav's Avatar
Exclamation
Yeah what does happen to the bracket? Keep it for a rainy day maybe?
Also I'm getting my Megan header and Megan S-pipe with a CEL canceler on the S-Pipe.
Is there anything I should know?
This is going on a 2008 tC for reference
___
Vladislav is offline
mikochu
95
07-24-2017 02:48 PM
mikochu
07-24-2017 02:48 PM
Otsego_Undead
71
09-21-2007 02:54 AM
hawgs74
01-27-2007 06:49 AM
Quick Reply: Header Install (DC Sports)
