tC Tech and DIY Info for the Scion tC
Header Install (DC Sports)
Old 08-02-2005, 12:50 AM
jrjust123's Avatar
yes i drilled it out to 1/2 inch, i turned the ignition on and disconnected the - terminal, and i tightened everything as tight as it will go, and this is the second time i tried it, first i used #42009, and it didnt work, so i bought #42002 and redid it, and it still does not work, i did it exactly as it was depicted
jrjust123 is offline
Old 08-02-2005, 01:32 AM
Kaeon's Avatar
Im sorry I wish I knew what to tell you... It normally works for DC users only people I heard didnt work was the Megan header users...
Kaeon is offline
Old 08-02-2005, 02:23 AM
jrjust123's Avatar
so it is all suposed to be as tight as it will go then correct? is there anything else that will turn that cel off?
Old 08-02-2005, 02:38 AM
jrjust123's Avatar
also would the fact that i tightened the hell out of the header bolts have any adverse effects< because i didnt have a torch rench so they are TIGHT.
Old 08-02-2005, 01:25 PM
seminoles68's Avatar
did you use the mounting brackets and did you ever get the cel after the install
seminoles68 is offline
Old 08-02-2005, 05:58 PM
jrjust123's Avatar
what mounting brackets
Old 08-02-2005, 07:19 PM
the factory mounting brackets the held the header to the bottom engine block
Old 08-02-2005, 07:45 PM
jrjust123's Avatar
no are you supoed to use those? i didnt think that you could.
Old 08-03-2005, 11:43 AM
That is what everyone says or you will break the welds on the engine because of engine movement
Old 08-09-2005, 04:10 PM
inblacktc's Avatar
This sucks. I installed the DC header in and did the Non-fouler trick and my CEL is till on in my 05 tc. I went over my work to make sure I did everything correct...
Is there something else that may work to get the CEL off?
inblacktc is offline
Old 08-16-2005, 03:24 PM
showcasezf's Avatar
i have another post, but i will try here as well. in the install i was told to use the anti fouler. i drilled them, but was i supposed to drill all the way through? like all the way through the bottom? i was told yes, i was just re-asssuring what was told to me. just drill all the way through one of them?
showcasezf is offline
Old 08-16-2005, 04:07 PM
Kaeon's Avatar
There is two anti fouls in a package. You drill all the way threw one of them.
Kaeon is offline
Old 08-21-2005, 04:51 AM
xxwicky25xx's Avatar
Default what does CEL MEAN?
Originally Posted by i64X
The spark plug anti fouler trick works great. I've gone over 3,000 on my car with this trick using the DC headers and I don't have a CEL yet.
yeah im new to all this, and i just wanted to know what CEL stands for
xxwicky25xx is offline
Old 08-21-2005, 02:07 PM
Kaeon's Avatar
CEL = Check Engine Light
Kaeon is offline
Old 08-26-2005, 04:39 AM
XD40tC's Avatar
Would a custom exhaust shop be able to do all this for me? Im getting this header next Friday and dont really have the resources (especially a drill) to do this install so would they be able to do the anti-fouler trick if I told them about it?
XD40tC is offline
Old 08-26-2005, 01:02 PM
Kaeon's Avatar
I don't see why not...
Kaeon is offline
Old 09-05-2005, 07:36 PM
XD40tC's Avatar
Wait, I have to use the stock mounting brackets? But where do they go? There are no bolts on the new header. ??? By the way I did the install myself and I didnt have to drill all the way through one of the anitfoulers to get the sensor through. So far no CEL and it sounds and performs great. By the way I hear a lot of air swooshing when I floor it, is that just the flow or is it bad?
XD40tC is offline
Old 09-05-2005, 08:00 PM
Kaeon's Avatar
Correct there is no place to mount the brackets to the new header...,
Kaeon is offline
Old 09-07-2005, 04:38 PM
PghtC's Avatar
Why is everyone surprised that they get a CEL? I mean you are removing the primary emissions component of the car. There is an O2 sensor on either side of it to determine if it is working. Without it there, there is no difference in readings between the two sensors, and BAM...you get the check engine light. I also do not like that the primary O2 sensor is reading off of only one cylinder on these headers. This causes the engine to tune off of one cylinder. If all three other cylinders are bad, but one is good, the computer thinks all is well when really it is not. This could cause a lean or rich condition. Meh...I am a header hater until someone comes up with something better.
PghtC is offline
Old 09-11-2005, 09:42 PM
The_Instigator's Avatar
Thnaks Kaeon...used the FAQ during my alphawerks install yesterday and it really helped. Worst part of the install was getting off that last header nut behind the alternator. Turns out mine was right at the angle where I couldnt get a wrench on it. Ended up using a 12mm socket with a u-joint adapter so I could break it loose with a ratchet. After that it was a breeze. O2 sensor came out perfectly and also did the anti-fouler mod with no CEL.
Thanks again
The_Instigator is offline
Quick Reply: Header Install (DC Sports)
