tC Tech and DIY Info for the Scion tC
LED Swap (Guages / HVAC)
Old Sep 28, 2006 | 10:51 PM
  #381
V0RT3X's Avatar
I would desolder everything and solder it back
When you solder, just point the iron tip to the base, then put the solder in there and it will fill it up, I dont know how to explain it. But make sure you use thin solder
Old Sep 29, 2006 | 02:03 AM
  #382
LEDMods_net's Avatar
Strictly Scionized
yea, when you are soldering pins, you want the "hershey kiss" look. Not the ball of solder, or glob of solder. Nice clean shiny hershey kiss...
Old Sep 29, 2006 | 02:12 AM
  #383
engifineer's Avatar
^^ yep, perfect description. nice, concave solder joint.
Old Sep 29, 2006 | 02:13 AM
  #384
Strictly Scionized
yea, you can look at the stock solder connections to compare.
Old Oct 16, 2006 | 01:58 AM
  #385
phiquach's Avatar
will these work?
http://www.eled.com/product.asp?cata...=EA3528RWC%2DJ
Old Oct 16, 2006 | 03:37 AM
  #386
V0RT3X's Avatar
yeah, they look like the PLCC size LED
Actually, when I did mine, I bought the wrong LED, I used the 1206 instead of PLCC and it worked too
Old Oct 16, 2006 | 04:02 AM
  #387
SquallLHeart's Avatar
^^ yeah.. they look good to me.
Old Oct 16, 2006 | 05:24 AM
  #388
phiquach's Avatar
yeah but are they too bright? 800 mcd too much?
Old Oct 16, 2006 | 05:28 AM
  #389
hmm.. neah.
Old Oct 16, 2006 | 03:11 PM
  #390
V0RT3X's Avatar
if they end up too bright, you can always crank down the intensity with the brightness adjustment dial thing in ur gauge. I think it's better to get the brightest LED u can get
Old Oct 24, 2006 | 05:31 AM
  #391
nick9871's Avatar
Hey my girlfriend wants to do this to her car. Well she wants me to do it for her ha ha.
Anyway does anyone know a specific LED part # that would appear to be hot pink?
I know you can only order certain colors of the LED's but I was looking at a site that sold them with varying translucence on the actual LED "cover" creating a different color.
I just have no idea which will produce the most hot-pinkish color.
Old Oct 24, 2006 | 06:19 AM
  #392
always with the pink..
you can try the pink leds available overseas... have seen them in and light up fine.. just not sure exactly how long the color's gonna last
Old Oct 24, 2006 | 01:37 PM
  #393
web's Avatar
web
My whites were 2000 mcd. You should be cool
Old Oct 24, 2006 | 01:38 PM
  #394
web's Avatar
web
Do you have any suggestions on how to desolder the LCD? I tried doing it one peg at a time but it did nothing. Is there a way to heat all the points up and slide the LCD out?
Old Oct 24, 2006 | 02:27 PM
  #395
V0RT3X's Avatar
I didn't do it like that
it's very simple, just remove as much solder as you can, then wiggle each leg, they should be able to move around. If not, just take the desoldering braid, and cut it into a triagle tip like this ^ , then point the tip inside the hole of the leg and try to suck it up. If that still doesn't work, take the soldering iron and point to the leg and just push it lighty to one side
After I desolder the LCD, all I have to do is lift up the PCB board and the LCD screen fall right off, dont even have to apply any pressure at all to get it out.
Old Oct 24, 2006 | 02:30 PM
  #396
web's Avatar
web
Ok cool. Sounds like a plan for this weekend .. Thanks
Old Oct 24, 2006 | 02:33 PM
  #397
V0RT3X's Avatar
Ok great. My damn LCD has that smear in it but it's not cracked. I think there's a piece of solder touching two rods and it's reading 2 signals at the same time b/c everything works on the screen, it just shows up at the same time
Hmm, just make sure all the solder are clean, if you can desolder the LCD and solder all these LED and resistors and wire, I dont see how you can mess up the LCD. Use a magnifying glass and see if there's any solder touching both legs
I just hope that's the case, otherwise, it means that you f*cked up ur LCD while desoldering and soldering. Good luck
Old Oct 24, 2006 | 02:48 PM
  #398
web's Avatar
web
Yeah. I think there may be a small piece connecting 1-2 pegs b/c I tried to desolder a few pegs at a time by touching 2-3 of them with the iron trying to melt the solder but it didn't work. I think there may have been some solder stuck on the iron tip and I never noticed it contacting the two pegs. If it did end up messing up the LCD, oh well. I can still read it pretty good. If it gets to be a huge pain, I'll just go get another one from the factory. Is it the whole HVAC they sell or just the LCD and white mount?
Old Oct 24, 2006 | 03:33 PM
  #399
engifineer's Avatar
If you desolder the first time, and it leaves solder down in the hole, it will be easier to add solder again, then desolder the leg. If you are really having problems using the wick, you can buy a heated desolder iron at radio shack for about $15 or so. That is an easy alternative as well. The trick is to take your time untill you can move all of the legs freely. You should be able to then let the LCD come out of the board without any force at all.
You have to buy the whole HVAC unit (about $500 from toyota) to replace the LCD. I reccomend finding one out of salvage (car-part.com) for $50 - $100 and taking the LCD from there if you damage yours.. much cheaper that way.
Old Oct 24, 2006 | 03:36 PM
  #400
web's Avatar
web
Sounds good. Thanks for the tips. I was just thinking of it and never used the wick on the reverse side of the board and desolder from the other side. I can't believe I never tried it. I'm a tard. If I desoler from the LCD side and suction from the reverse side, it will suck the solder out from the bottom leaving a clean hole. Damn.............gonna try maybe tonight now.........haha
