LED Swap (Guages / HVAC)
#83
Originally Posted by raWr215
question, after prying and putting back the car together... do you notice anything is wrong with the dash boards etc? like loose, not in perfectly etc?
#86
Man, I want to change mine so bad but still not brave enough to do it. Only because I'm affraid the needle will not be accurate again. I once had accord and it wasn't accurate anymore after I mess with it. Maybe one day but I guess I have to learn how to solder first huh?
#87
#89
Originally Posted by red718
is 5000 or 7000 mcd going to blind me
#91
They're bright.. but won't blind you (haha obviously) I have 4 22000 mcd white leds in an altoids can, FRICKING BRIGHT, my friend pointed it right into my face... not blind.. but I bet it did something bad to my eyes lol
#93
Originally Posted by smokeyzx
I broke the center console LCD last night. Any ideas on a cheap replacement?
You have to buy the whole board to replace the LCD. I would look for one from salvage if possible.
As I mention in the how to on replacing the center console LEDs and making them as bright as the gauges, be VERY patient with the LCD. Even after it appears you have wicked all of the solder off the pins, there will still be some further down in the holes. You have to keep heating and wicking (do pins far apart alternately to prevent overheating one area) untill it all comes out. When it is ready you should be able to wiggle the LCD and see all pins move on the other side of the board. If not, keep working on those that do not move.
#100
Let me get this straight.....other then the LEDS their is nothing else you have to buy to make this project work? Correct? I don't want to buy the LEDS and install them and have it blow out because i had to buy RESISTORS.
