Pulley Install (NST, Underdrive Crank, Water Pump, Alternator)
Not at all.... Are you running an automatic possibly? That may be a small difference.... I took your comments into consideration when I did it, but it just pulled off and the new one just slid right on....
The only waterpump issue is just the tight frickin' bolts that hold it on....
yeah my car is an auto. Always seems like stuff is just a little to tight or just off with it. Ehhh what cha gonna do? he he.... Yeah i had to use a strap wrench and fancy words to gt the water pulley bolts loose too.
NICE except i never needed a pulley remover for my crank pulley. all i did was once the bolt was removed it came right off with a tiny bit of wiggling and the new one went on NP. I am only saying this because if you dont have a pulley remover, dont worry about getting one because you really dont need it.
The puller tool is not always a necessity, sometimes crank pulleys actually slide off pretty easily. Just to be on the safe side though, you could always go to your local autozone and actually rent one for FREE. Just put down a small deposit and they will return it once you bring the tool back
ok now - whats the dirt on people saying that this is not a good upgrade for the long term of your car? I am interested in hearing the downside of this because if there wasnt any everybody would be doing this without even questioning it. From what I hear the performance gain is there just by driving the car ....you know there is a difference. I am not running a large sound system. The most I am going to do is change out my headunit in a year or so, add one 25x4 amp and keep my 8inch bass tube. Ive had large systems in my cars in the past and they were great. This cars sound is going to have 2 small amps max. ( figured i would say that so people know how to respond w/ better details).
There is nothing negative in regards to audio/water anyone has even discussed.... but, If you run a large system, it is best to get the overdrive alternator pulley just to be sure you're charging well enough for it...
The discussions revolved around the lack of a harmonic dampener in the tC aftermarket pulleys... and that the stock pulley has a rubber insert which is debated to reduce harmonic vibrations, which possibly could damage your engine over time, per others debate...
The examples stated were of Supra engines that were pushing some MAJOR HP... and I know of many running lightweight and underdrive pulleys for 70+ thousand miles with no problems whatsoever... so I really took their consideration into account, but ultimately decided that there wasn't any real information I could find anywhere on google to back up those claims and I found many things stating all the positive results people achieved....
You shouldn't have a problem to worry about at all....
so im sitting here playing with my pully waiting to install it when i get off work
but i cant figure out wtf these 2 threaded wholes are on the side of where the pully bolts to the crank
any one know??? im about 100% sure they dont get used in the install
thanks thats what i figgured
yeah the pulley pullers you are supposed to use to remove harmonic dampers/balancers (a.k.a. crank pullies) actually screw into holes in the pulley. Hence the reason they are there. The puller he used was a gear puller. Works just as well.
