xA Tech and DIY Info for the Scion xA
Alarm Programming (Scion Security) for the xA, and not other models
Old 12-10-2004, 06:57 AM
Team Sushi
djct_watt's Avatar
we're talking about the passive function, which arms the system if you forget to press the lock button. . . but I am unsure that my "arming" they mean lock as well. . . it may just "arm" the alarm without locking the doors (if you enable the passive mode and forget to lock your doors).
djct_watt is offline
Old 12-10-2004, 11:24 AM
Slyfx13's Avatar
OOOH!
Slyfx13 is offline
Old 04-05-2005, 05:16 AM
GoLiAtH's Avatar
Default Problem With Alarm
Check out this: when I turn on the alarm, you know the door locks and the headlights turn on for about 20 seconds, cool, but after that when the lights turn off the horn beeps very fast for about four times. Can you help me on that???
GoLiAtH is offline
Old 04-05-2005, 09:23 AM
Team Sushi
djct_watt's Avatar
headlights turn on for 20 seconds? I don't think you have a factory alarm. . . maybe a karr unit or something aftermarket the dealer installed?
Old 04-05-2005, 11:08 PM
GoLiAtH's Avatar
All I Know it is factory alarm here in PR.
GoLiAtH is offline
Old 04-06-2005, 09:52 AM
Team Sushi
djct_watt's Avatar
is there a little square thing, next to your mirror controls, that says "Security"? It should have an LED and a small microphone (glass break sensor). There should also be a sticker on the window that says "protected by Scion Security," or something like that. If you don't have those, odds are it is not a factory alarm, factory meaning something that was installed by the port (which is controlled and run by Toyota). That, or factory meaning that the dealer installed the OEM spec parts. Many dealers offer better (and in some cases worse and malfunctioning) alarms that they slap onto the car.
Old 02-15-2006, 03:22 AM
titolito's Avatar
Wow!
Up, Up, Down, Down, Left Right, Left, Right, B, A, Select, Start!
titolito is offline
Old 02-17-2006, 09:44 PM
ImportCarPartsPlus's Avatar
It isn't much of a problem to disable the factory alarm.
ImportCarPartsPlus is offline
Old 03-17-2006, 10:32 PM
PghtC's Avatar
Wow! Silly
Actually...
Up, Up, Down, Down, Left Right, Left, Right, B, A, B, A, Select, Start!
you forgot a B, A pattern. And this is for two players. Remove select for one. :D
PghtC is offline
Old 04-03-2006, 01:19 AM
Admin Emeritus
Tomas's Avatar
The Xa, xB, and tC have totally different "Toyota VIP" alarm systems.
The xB Toyota VIP alarm does NOT have a beeper or buzzer, the xA does. That is merely the most obvious difference. There is a vast difference in the programing, also.
For those with the Scion official, optional, Toyota VIP alarm in a Scion xB, this is the manual that the dealer should have given you - the Alarm System Owner's Manual.
If the dealer did NOT give you this manual with your alarm, beat them soundly about the head and shoulders until they cough one up - it is *required* that they give the original owner of the alarm system the owner's manual.
Here's a .pdf I made of my Scion xB alarm owner's manual:
http://tijil.org/scionlife/xB_VIP.pdf
If you have the Scion alarm in your xB (but NOT the one in the RS3, according to RUMORS), save a copy of this PDF... you may need it someday.
Tomas is offline
Old 08-26-2006, 05:37 AM
streamline_jdm's Avatar
Looking for help on how to turn off my passive alarm ? is there anyway we can turn that thing off ?? Don't want that feature. any help ??
streamline_jdm is offline
Old 08-26-2006, 09:57 AM
Admin Emeritus
Tomas's Avatar
If your passive arming can be turned off, the instructions should be in the alarm owner's manual your dealer gave you.
Since it is a different system, the arm/disarm is likely different from the "normal" alarm.
Tomas
Tomas is offline
Old 01-01-2007, 02:38 AM
dand's Avatar
I tried the passive arming -- it arms the alarm but did not lock the doors. This is with the xA.
dand is offline
Old 01-01-2007, 02:42 AM
Admin Emeritus
Tomas's Avatar
That is correct. I sets the alarm but does not lock the doors - it has NO idea if you are maybe loading/unloading stuff, and might even have left the keys/remote in the car.
It is correct for the system to set the alarm to protect itself without potentially locking your keys in.
WORKS THE SAME ON THE xB.
Tom
Tomas is offline
Old 08-15-2010, 08:47 PM
MADD1's Avatar
Default Passive alarm
My 04 xB passive alarm works as the instructions direct. If you have the passive alarm set and unlock the doors but don't open the doors the passive alarm setting will relock the doors when the alarm resets. It will not lock the doors after you open them but will set the alarm.
MADD1 is offline
Old 11-13-2021, 11:17 PM
rvillago's Avatar
This guide do not work in my Scion 2004....
____
rvillago is offline
George
120
08-30-2022 12:00 AM
ThaClutch
06-24-2017 06:12 PM
adam1991
49
03-30-2006 04:32 AM
ddreg
9
02-02-2005 04:02 AM
NoShiO
10-02-2004 03:05 AM
Quick Reply: Alarm Programming (Scion Security) for the xA, and not other models
