Bulb Sizes
Bulb Sizes
Headlights: H4 / 9003*
Foglights: 9006
Brake Lights: 7443
Rear Turn Signals: 7440-A**
Front Turn Signals: 1157NA**
Side Markers: 194
Reverse Lights: 7440
3rd Brake Light: 124
*If you want Sylvania Silverstars, you must get the 9003, for the H4 will not fit or have correct beam pattern
** Corrected --Tomas
Please post here if you know any of the other bulb sizes. Thanks.
Andrew
Foglights: 9006
Brake Lights: 7443
Side Markers: 194
Andrew
FYI if anyone even looks at this post: Do not get such a high wattage bulb like I was going to do. I got some advice....since it is running 55on low and 60-65ish (forgot) high beam, you dont want to push anything higher or you may run into the risk of damaging wires. The Gentlemen told me it is best to just get the running lights aka foglights
ok then i got a question. You said that the H4 bulbs will not work correctly?
Andrew
Originally Posted by hTXb
Any idea what size bulbs are used behind the dash? Trying to figure out which bulb covers to buy... :?
Michoku, what size did you buy when you re-colored your dash lights?
I don't reccommend the bulb covers, they're hella-dim!
Doesn't anybody know the size of the little bulbs that are used to light the climate control? They're prtty tiny. I wonder what they are. Would like to get colored ones instead of the existing ones that have the tiny yellow rubber on them.
Revolt Imports
DeepSouth Scions
For any of the smaller bulbs, 194, 74, ect., go to this website. http://superbrightleds.com/1157.htm They have whatever your looking for in a lot of colors. I bought some blue ones from them when I had my Protege5. They are really bright and they ship fast.[/url]
It's hard to tell brom the picture how bright they are, but the lights were green and I changed them to blue.
Why do you say this? I have the H4 silverstars in my xb and they fit fine and the beam pattern is the same as stock :?
I've got 100W headlight bulbs, and I've been running them for a couple of weeks now with no problems to the wiring. The headlight system has relays in it, which will allow for a higher wattage bulb. In older cars without relays, burning up was a common problem, but not nowadays.
Hope this helps!
Joe
Scinergy IA
Hope this helps!
Joe
Scinergy IA
