Cargo Cover (custom, hard)
Originally Posted by Box916
Ok, so am I the only person who doesn't know what MDF is?
And why would you want a hard rear cover? Just a couple of questions...thanks!!
here is a quick info sheet on it..
http://www.design-technology.org/mdf.htm
i like the hard cover idea. it won't flap like a soft cover.
it can support some weight. it hide whatever is below it.
Max, how much weight do you think it can hold?
...and you could set something on top of the cover Max made should you want to. It becomes another usable shelf.
And XBMAN.. it's PVC pipe, not PCP. Two totally different things..
Has anyone attempted making a fiberglass version? Maybe using the US cover as a template then just laying fiberglass matt a few layers think then cutting to fit and sanding it to finish it off? I would just think it would be lighter and little smaller. Maybe I will try this soon. I just need to get a template.
Originally Posted by svnwrnch
Great Job! I'm gonna do this myself, Just one thing I am gonna to add the word "scion" under the symbol, i cant copy you completly!
Im not trying to thread hijack, just sharing.
Heres mine I did a few months back. Fits end to end and tailgate to back of the seat. Its held up by 2 aluminum L chanels that were cut the length of the sides and screwed to the side panels. It can hold quite a bit I have seen, my wife will come home from the grocery store with food and stuff pilled on top of it when there isnt any room left under it. I added the speakers to it because I wasnt able to hear the ones in the side panels anymore, and the bazooka got louder as well. I covered it in bedliner spray.
other than the "screwed to the side panels" - sounds/looks great. Then again, you can't see the L-brackets... so what's it matter I guess. The only other way around the mounting problem is to extend your cover to each side with upward angled "wings" that rest on the light grey portion under the quarter glass
well i made it today, it fits really tight and rest right against the top of my box perfectly. i didn't put any logo or any thing on it. i think it makes my subs louder also,well when the door is closed, makes a good shelf, when i went to the super market before i had to put everything in the back seat because of my box, now i have room to put stuff back there. sorry no pics. i'm going to throw some neon lights underneath the board and a plug on it for when i take it out, maybe tomorrow if i get a chance.
that is way cool. with a little work, it could look factory. the vinyl hangs off the sides a little too much for me, other than that i like it alot. i really like the scion logo in the center!
Originally Posted by Max2k
N2twhlz: Did you just trace the cargo cover and cut it from wood?
A little warning to those considering this... The vinyl/PVC combination does not work well. Any bump in the road and the movement of the two leads to a lot of squeaking. I made another one tonight. I found some fabric which very closely matches the seat fabric on the sides. I also used plywood this time rather than MDF. I was a little concerned with the MDF sagging over time, although it appeared fine so far. I got everything done, start to finish, in well under two hours. Upon initial inspection the squeaks are gone, although I have not driven around yet. I did not put a raised emblem. I have other plans. It was dark when I put the cover in, so no pics yet. I'll get them up tomorrow evening.
