Fog Light Activation Without Headlights
Hello again.
The only way to turn you foglights on is with your headlights. What this mod will do is let you turn you foglights on with your corner lights. You will be able to turn the foglights off and on aswell. The foglights will work just like stock but they will come on with the corner lights instead of the headlights. I think it looks good with the corners and the foglights on. This mod should only take 45min-1hour. Here we go. You will need to take your center dash off. To do that you need to take off all 3 of your a/c knobs. https://i53.photobucket.com/albums/g.../fogs20001.jpg Unscrew the 2 screws at either end of the a/c knobs. https://i53.photobucket.com/albums/g...g/IMG_1474.jpg Grab the top of your dash and pull down and out to pop it off. https://i53.photobucket.com/albums/g...g/IMG_1479.jpg On the back of the consult you will find 3 wire harness. https://i53.photobucket.com/albums/g...g/IMG_1481.jpg Unplug all 3 of them to get your center dash free. https://i53.photobucket.com/albums/g...g/IMG_1482.jpg Now grab the lower consult and pull that out. https://i53.photobucket.com/albums/g...g/IMG_1484.jpg Now depending on what year you have you will find 2 or 3 harness on the back of it. https://i53.photobucket.com/albums/g...g/IMG_1485.jpg Unplug all of them to get it free. https://i53.photobucket.com/albums/g...g/IMG_1486.jpg At the back of the ceter dash on the left is a bolt, unscrew it . https://i53.photobucket.com/albums/g...g/IMG_1488.jpg Attach 2 9inch wires to an open connector. (These 2 wires are going to be your ground wires) https://i53.photobucket.com/albums/g...g/IMG_1491.jpg Screw the bolt and connector back in. https://i53.photobucket.com/albums/g...g/IMG_1492.jpg Now find the harness that was connected to the foglight switch and cut the loom open. https://i53.photobucket.com/albums/g...g/IMG_1487.jpg Cut the black wire. https://i53.photobucket.com/albums/g...g/IMG_1497.jpg On the end attached to the plug connect a 9inch wire to it. https://i53.photobucket.com/albums/g...g/IMG_1498.jpg Use electrical tape to tape the loom back together with the wire sticking out. https://i53.photobucket.com/albums/g...g/IMG_1499.jpg Side note. For my ignition wire I taped into the parking light 12v so the fogs come off/on with the parking lights. Another ignition wire you can use is the cig lighter 12v. Doing it this way turns the fog lights into "running lights" that come on when the key is on - but you can still switch them off using the fog light switch. In the center of the dash were you disconnected the 3 wire harness find the bigger harness. https://i53.photobucket.com/albums/g...g/IMG_1493.jpg Unrap the electrical tape and find and splice open the green wire. https://i53.photobucket.com/albums/g...g/IMG_1494.jpg Connect a 16inch wire to the green wire and wrap it back up with electrical tape. Run the other end of the wire down to the bottom of the dash were the other wires are.(This wire is going to be your ignition wire) https://i53.photobucket.com/albums/g...g/IMG_1495.jpg Attach one of these connectors to the 4 wires that you now have. https://i53.photobucket.com/albums/g...g/IMG_1501.jpg You should now have 4 wires that look like this. https://i53.photobucket.com/albums/g...g/IMG_1502.jpg You will need to go out and buy a relay form you local auto parts store. https://i53.photobucket.com/albums/g...g/IMG_1467.jpg Here is the wiring diogram that I used. https://i53.photobucket.com/albums/g...schematic2.jpg This is what the bottom of the relay is going to look like. https://i53.photobucket.com/albums/g...g/IMG_1496.jpg Plug in the wires were the diagram says to put them. This is what the relay will look like with all of the wires attached. https://i53.photobucket.com/albums/g...g/IMG_1505.jpg Put the relay in a place were nothing will mess with it. And your all done. Just put your dash back together and turn on your foglights buy turning on your corner lights. It should look something like this. https://i53.photobucket.com/albums/g...g/IMG_1506.jpg https://i53.photobucket.com/albums/g...g/IMG_1507.jpg I hope you like it and good luck. |
will this mod enable you to keep the fog lights on when the hi beams are in use?
Always nice when someone attaches photos to a DIY... :clap:
Always nice when you get two posts for the price of one. :P
Naw, just kidding! Sweet mod... right now, I have them wired so they come on independently, but this might be something to do soon. |
nothin like bustin a double posters chops. ive been in that seat too many times lol
I have no clue why it double posted... :tap:
Thanks for all of the posts guys.
this pretty cool man, thanks, i got my fogs wired up so i can turn them on any time i want, even if the parking lights are off, only problem is, if i turn them on, i risk leaving them on when i turn the car off cause there is no warning sound when you turn off the ignition. i think i might do this once it gets warn out around here. i always have the parking lights on anyways when my fogs are on.
If you wanna wire them so you can turn them on whenever, you just need to ground the black wire to that one screw... that's it.
Originally Posted by greenguyshrek
If you do it this way then some people tend to forget to turn them off when you turn your car off.
I hope this works out for both of you^^^
:ponder: hmm.. this looks familiar...:wink:
probably cause shrek did my fogs and sidemarkers on saturday. thanks again shrek! :clap: :clap: :clap: |
Use a relay
If you want to be able to turn them on / off independently but not worry about running down your battery by leaving them on, you could use a relay.
Just a suggestion. I am using a relay to make it so I can turn the LEDs in my Oh Jesus handles on / off with a switch, but only when the key is on. &E; |
I did this last night, but i guess i messed something up somewhere cause mine don't cut off when i turn the lights off.
I can still turn them on and off whenever, I will look back over this sometime and try and figure out what I did wrong. |
Re: Use a relay
So i guess if i wanted to make my fog day time running lights i would just substitute a hot leed for the green wire out of the center wire harness?
