View Full Version : Strut Brace Install (Front, DME)
davedavetC
05-04-2007, 05:27 PM
ok so basically this is a 5 minute job, but its a fun 5 minute job. i jsut wanted to say again how easy and great it was to do business with NST (the peoples who sell the DME bars front and rear (i will post an install shortly after this one for the rear).
so here we go!
Tools needed:
ratchet set (14 mm i belive is all you'll need. just get a set just incase, i know for the rear you will need a 10mm to take the panels off to access the strut bolts).
Flat Head Screw Driver.
and a Phillips head screw driver (or anything with a point, like a pen or somethin just to pop the clips on the windshield wiper cowl)
and 5 minutes :P
ok so start by popping hood (duh!) :)
now locate teh windshield washer caps (1 plastic cap on each blade) and use the flat head to pop it off as shown.
http://i57.photobucket.com/albums/g209/zdawg913/davedave001.jpg
(repeat for other blade)
now use the 14 mm socket to remove that nut and place somewhere save so you wont lose it! *i placed all bolts right on the battery*
now with out the wiperblades
http://i57.photobucket.com/albums/g209/zdawg913/davedave003.jpg
get the philips head screw driver and pop the 4 clips 2 on each side (i didnt take a pic of these because whoops... mine are missing :doh: )
and once those clips are gone place hands here and pull up and out
http://i57.photobucket.com/albums/g209/zdawg913/davedave004.jpg
and now with the wiper cowl out. here comes the fun part :D
http://i57.photobucket.com/albums/g209/zdawg913/davedave005.jpg
take the 14 mm again and loosen and take off all 3 bolts on the strut bolts.
http://i57.photobucket.com/albums/g209/zdawg913/davedave006.jpg
http://i57.photobucket.com/albums/g209/zdawg913/davedave007.jpg
once all 6 bolts are off you can place the strut bar in place and bolt it back on :D
http://i57.photobucket.com/albums/g209/zdawg913/davedave008.jpg
http://i57.photobucket.com/albums/g209/zdawg913/davedave010.jpg
now tighten them all up so they are nice and snug, and reinstall the wiper cowl just like you took it out.... but backwards :P then put the wiperblades back on and the caps that go over the nuts, check all work for loose bolts and if you want put the cool DME logo on the strut bar or anywhere else just make sure to represent! :lol:
http://i57.photobucket.com/albums/g209/zdawg913/davedave015.jpg
http://i57.photobucket.com/albums/g209/zdawg913/davedave014.jpg
http://i57.photobucket.com/albums/g209/zdawg913/davedave013.jpg
enjoy!
and dont forget if you like it hit up
www.nonstoptuning.com for the best deal and customer service you can get.
also dont forget to check out their pulleys and the DME radiator plate!!
link for the rear strut bar install (http://www.scionlife.com/forums/viewtopic.php?p=2544369#2544369) (which is a little more involved then this one mostly because you have to remove the trunk panels and cut a tiny bit)
tc913
05-04-2007, 06:50 PM
You didn't jack the car up??
davedavetC
05-04-2007, 07:13 PM
nah i did it when i had the DC sports, and theres no difference. i didnt see a need to jack the car up. plus with this one you have to take all 3 top mounts off and in my head i pictured teh strut assemblys falling when i jacked it up. so i said screw it and just installed with out jacking
mike6789k
05-05-2007, 02:01 AM
whats the point of jacking it up?
i'd imagine it'd be unsafe if you did that lol
tc913
05-05-2007, 02:44 AM
I thought that jacking up the car would release the tension in the struts to make it actually perform when you put it on. Maybe I was informed wrong but that does sound correct. The bottom struts have bolts on so it wouldn't actually fall off.
mike6789k
05-05-2007, 03:08 AM
ooh you're right, yea that would make sense, just jack it enough to release suspension load but not take the wheels off the ground
Bozuzu
05-05-2007, 09:22 PM
since the force on the struts is upward with the suspension loaded (car on the ground), jacking the car up for this install would be counterintuitive-it would actually make it harder.
Importspeed
05-13-2007, 08:58 PM
i installed the dc strut the first time with out jacking the car up and still i feel nothing different and then yesterday i jack the car up and did the same thing and still nothing when i had a strut bar on my lancer i felt a big difference in handleing why not with the tc ????
ADRdesignCo
05-14-2007, 08:42 PM
mainly cause the build of the tC and the location of the strut bar. i felt the same way with my Dodge Avenger when i added it, but since the strut towers are pretty high in the engine bay its not too noticeable. at least thats what i understand...
and myabe its just me but the DMEs look alot like the Greddys.
SidePocketKid
05-19-2007, 03:43 AM
for the people who have this, did you have to "assemble" the bar when you got it?
im having a bit of an issue here...the long threaded bolt that connects the bar to the bare metal pieces that bolt onto the 3 strut bolts wont bolt on tightly, even w/ the washers in place...it seems like the smaller bolt has a plastic ring in the inside threads making it impossible to go through...
davedavetC
05-19-2007, 05:09 AM
yea the bar has to be assembled sorry i didnt put that part in there.
i got you on aim tho :wink:
SidePocketKid
05-19-2007, 07:12 AM
an allen wrench or vice grip will be required for assembly
i suggest you just get the bare metal parts on the strut bolts first, and then tighten up the bar afterwards.
paul_dezod
05-21-2007, 06:01 PM
Excellent DIY Dave!!!
We are now carry DME products as well. :)
davedavetC
05-21-2007, 09:26 PM
thanks paul!
jwaggz82
11-29-2008, 12:27 AM
how many lbs of force to put the wiper bolts back on? and how much on the strut bar bolts? I hear that the stock on the strut bar is 38lbs but with the strut bar you want a few more lbs (maybe about 40-45lbs) ....
but the last thing I want to do is strip the bolts. Also, you should be using lock tight w/ the strut bar install right?
BZinn1
11-29-2008, 02:38 AM
I did not use loctite on mine.Just use a torque wrench and I think it was about 38-40lbs I did mine at.
jwaggz82
11-29-2008, 03:07 AM
I really need to know the windshield wiper torque - yea the strut bolts are 38-40lbs
ippskidder
12-16-2008, 05:42 PM
BUMP!
insight420
09-23-2009, 04:34 AM
i've had the DME front strut bar installed for about 2 months now and im very pleased with it. it literally took all of 10 minutes to install, and most of that was spent fighting the wiper cowl...(i really dislike those plastic clips that toyota used, i ended up damaging like all of them:doh:). my impressions are that my tC actually feels better controlled going over bumps/ridges/tracks in the road. its like the bump doesn't reach the passenger compartment anymore, instead the suspension just reacts effectively. i've also noticed my steering to be much more stable at highway speeds and my cornering ability to be much tighter. great product, im very pleased:clap:.
lastly, i thought it was pretty sweet to be able to put the DME badge on my front grill to represent.
xdejablu3x
09-25-2009, 12:40 AM
are you guys able to flex the strut bar? like, bend it if you apply some sort of amount of pressure to it. a lot of people tell me that a well performed strut bar is rigid and solid to where there is no possible flex.
Domo
09-25-2009, 12:45 AM
you can not flex it by hand. This bar is super sturdy..way sturdier then my POS trd strut bar.
xdejablu3x
09-25-2009, 02:11 AM
well thats good. im just debating if i should risk getting the ebay (knock off DC strut bar) strut bar or just save up and getting an aftermarket one.
Ace83
09-25-2009, 02:21 AM
does it really make a difference? the way our struts looks it seems pretty stable even w/o a bar. Ive heard reviews that they dont notice any after strut bar is installed on the tc
Domo
09-25-2009, 02:23 AM
You really dont notice any difference since our strut bars are bolted on, not welded on. However I did notice a very slight difference with the DME strut bar when I had it on my ride. The front felt a tiny bit more stable around corners compared to my TRD strut bar which is weak. I feel like i can bend the TRD bar with my toes.
insight420
09-25-2009, 05:33 AM
i dont know how strong other bars are, but my DME only flexes the smallest amount if i basically lean my full weight on it. im a big guy, trust me.
Domo
09-25-2009, 05:43 AM
I find this hard to believe. The DME bar is super sturdy. Trust me, if you flex it..it will be permanently warped. So I dont believe this to be the right term but you can even tell that the welding on the bar is quality. The bar utilizes 3 points instead of the traditional 2 points on common tower bars.
insight420
11-15-2009, 07:01 AM
ah, i didn't make myself clear, i wasn't being critical of my front DME bar. actually i love the damned thing! it's sturdy, good looking, and is an effective bolt-on IMO.
yirichie
11-15-2009, 07:11 AM
Anyone else have a hard time popping off the wipers??
And how do I reach the top left piece in this picture without the use of an adjustable?
Not sure what dave did but there is this piece that hangs over it making it unreachable?
davedavetC
11-15-2009, 01:48 PM
i bent it :)
jwaggz82
11-15-2009, 03:08 PM
on the wiper there is a plastic cover, under that is a scew. Unscrew it and the wiper comes right off. Take both off and then pop the plastic off and you have plenty of room.
yirichie
11-15-2009, 04:56 PM
Yeah even after I pop off the plastic and the nut.. BOTH wipers are still stuck on there pretty tight.. Seems nobody else has this problem? :|
And thanks dave haha
jwaggz82
11-15-2009, 06:13 PM
^ your using a ratchet? spray some wd40 on them and let it sit for 5min - spray a tad more - let sit for 5min - then try.
yirichie
11-15-2009, 06:33 PM
Eh a ratchet? I used a flathead to take off the plastic clip and a socket wrench to take off the nut? My problem is that when both the clip and the nut are off, when I tug on the wipers they do not budge haha. I'll try some PB Blaster though, thanks!
jwaggz82
11-15-2009, 09:09 PM
oh i get what you mean - take a flathead screwdriver and pry it easily - it will come up
davedavetC
11-15-2009, 09:11 PM
wiggle the wipers near the bend.
Domo
11-15-2009, 09:15 PM
yea you kinda have to squeeze it in there but once you get it in there, you dont have to ever worry about removing the it because the bar can be removed by itself
Scion_42
11-16-2009, 01:28 AM
good DIY. will be using this for my strut bar :)
xdejablu3x
03-22-2010, 12:35 AM
does anyone think this is legit? sellers on ebay have DME strut bars way cheaper then NST.
http://cgi.ebay.com/ebaymotors/DME-05-06-07-08-SCION-TC-REAR-STRUT-BRACE-TOWER-BAR-JDM_W0QQcmdZViewItemQQhashZitem53dfe3fffaQQitemZ360238546938QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
draxxus0321
02-25-2011, 07:34 AM
hey man i bought both mine off ebay and they seem legit
