!!!!Fujita Cold Air Intake...Please read!!!!
Old May 5, 2007 | 03:43 AM
TrickedRide1's Avatar
Default !!!!Fujita Cold Air Intake...Please read!!!!
Has anyone purchased the Fujita CAI for the 2007..if so did you have any problems with it????? i installed mine the other day and the check engine light came on....I double check all fittings, hoses, and was very careful with the sensor i also disconnected the battery for over an hour in order to reset the ECM after 35 miles the check light comes on... i bought a code reader and it says that the problem is the intake...im very ____ed and confused....anyone have any ideas what the problem is???? Thanks in advance
Old May 5, 2007 | 03:49 AM
scion_jon's Avatar
it doesnt fit o7 tb's are different
Old May 5, 2007 | 03:53 AM
what doesnt fit?? tb's??
Old May 5, 2007 | 03:56 AM
scion_jon's Avatar
the intake itself doesnt fit the throttle body, thats one of the difference between the 07's and th 05's-06's
Old May 5, 2007 | 04:01 AM
when i put it on everything seemed to fit perfect and the company claims its for the 07
Old May 5, 2007 | 04:02 AM
scion_jon's Avatar
hmmm, if thats so maybe im thinking of a different intake.
but i think fujita was one of the intakes that didnt fit the new 07's
Old May 5, 2007 | 04:09 AM
its def. on their website http://www.f5air.com/applications.html
Old May 5, 2007 | 04:12 AM
scion_jon's Avatar
hmm yes it is, perhaps im wrong, but what if they sent you a 05-06 model :/, do you think that could be the misfortune?
Old May 5, 2007 | 04:17 AM
well everything that came with it says 07 the only diff is the maf and the pic on their site for the 05-06 looks diff than what i have....the CAI is working its just throwing a cell
Old May 5, 2007 | 04:19 AM
scion_jon's Avatar
thats wierd
Old May 5, 2007 | 04:24 AM
tonytc05's Avatar
Put it back to stock and take it to a dealer and have them check it out. I think it's the maf that went bad.
Old May 5, 2007 | 04:31 AM
im def. gonna put the stock back on tomorrow to see if it fixes the prob...
Old May 5, 2007 | 12:10 PM
Mid_Life_tC-risis's Avatar
Sounds like you've done everything right. If you damaged the MAF sensor that should show up soon after you start up, not 35 miles later.
Might just be an ECU "hiccup". If you haven't already, reset the ECU to clear the CEL - just disconnect the batt negative for 30 seconds - then let the car idle for about 5 minutes. Then take it for a drive - easy does it for the first few miles - & see if CEL comes back.
Old May 7, 2007 | 02:28 AM
stayed off till 75miles this time
Old May 7, 2007 | 10:25 AM
Hmmm ... this reminds me of the header CEL thread.
Did you read the new code?
Old May 7, 2007 | 10:53 AM
i didnt even bother its always the same, im goin to work now ill check it before i leave
Old May 7, 2007 | 02:00 PM
OK. Post up the exact code numbers and any other info, even if you think it's not important. It's easier for us to troubleshoot from afar the more details we have to work with.
Old May 7, 2007 | 02:04 PM
D4u2s0t's Avatar
what's the code? it;s probably p0170, right?
and guys, keep in mind that when you're messing with things in a new car, you may get a cel. that's a part of modding. if it's something that you're very worried about, just leave the car stock. because if you keep modding, sooner or later you WILL throw a code.
Old May 7, 2007 | 08:16 PM
P0101 mass or volume circuit range performance problem...I called Fujita and they said that they have not had anyone call about the 07 and they want me to send em pics of the intake
Old May 7, 2007 | 09:10 PM
tC9o9's Avatar
incorrect info, the throttle body is the same unit.
the MAF is different, it is smaller than the 05-06. Also, fujita DOES make an 07 intake, you probably damages something when you were installing it. the MAF is very sensitive.
