215 /45R17 or 225/45R17
Old May 5, 2007 | 05:04 PM
himynameischris's Avatar
Default 215 /45R17 or 225/45R17
whats the difference between the two on 17's?
i dont know anything about wheels.
Old May 5, 2007 | 05:16 PM
TeeCizzle's Avatar
225 are a slighty Wider than 215...
I got the Hankook Ventus Sport K104 225/45/17's
I got mine from:
www.wheelsmarket.com
$101 per tire...Plus FREE shipping..
Old May 6, 2007 | 01:33 AM
CuRiOuSfIsH's Avatar
you will have taller sidewall, wider contact area, taller gearing (transmission), more weight.
Old May 6, 2007 | 02:34 AM
falkor's Avatar
Taller sidewall ?
Old May 6, 2007 | 04:46 AM
Tecrun19's Avatar
They are just 10mm wider than the 215 (215+10 = 225). If you are putting any tires on the stock rims put 225's on. I did with mine and it helps to cut down on rim rash and it has more contact area
Old May 6, 2007 | 08:54 PM
Originally Posted by falkor
Taller sidewall ?
sorry, thicker sidewall, more profile.
Old May 9, 2007 | 12:17 PM
JustAtC's Avatar
go to supraforums.com and click on tehnical...you will find a couple different software that will tell you exact the different and also how your speedo is impacted..mostly faster than oem tire/rims.
Old May 25, 2007 | 08:27 AM
richardsayzz's Avatar
how would the speedo be effected when the tire is only wider? its not like the tire is taller...i mean one spin should be the same right ?
Old May 25, 2007 | 08:57 AM
sciontc_mich's Avatar
The diameter is different between the two different size tires. A spin would be the the circumference of the tire, and one spin would take longer to get around if the diameter was larger. Which it is. Usually speedometers have a range of 3% variance to allow for different size tires. The link that justatc put up would help in showing you how much of a difference from stock (215/45-17) size would be.
silverevo05
Jan 9, 2007 08:46 PM
neckbonenick
Oct 26, 2006 03:00 AM
active9x
27
May 20, 2006 02:49 PM
Nick06tC
Scion tC 1G Wheel & Tire
18
May 14, 2006 05:49 PM
beezyyy
Feb 17, 2006 06:31 PM
