TRD s/c leaking, Need help for the dealer. Heat shield HELP
Old May 8, 2007 | 10:26 PM
articis's Avatar
Default TRD s/c leaking, Need help for the dealer. Heat shield HELP
Hi all I have the trd s/c and it is leaking oil. I installed nst crank and s/c pulley. Also a MMW Header, but I got the header coated in jethot 2000 coating.
I only have 6000 more miles on the tc warranty. I think i need to take those aftermarket parts off to make it look like stock before I go in the dealer.
What I need from someone is the trd stock heat shield. Mine is kinda banged up. If someone could let me borrow thiers that their not using or buy it that would be great. I got to get this fixed.
Also has anyone made a good intake for the s/c? Ive been looking but doesnt seem to be in production yet.
thanks
Old May 9, 2007 | 01:50 AM
O5_TRD_tC's Avatar
y r u making the dealership pay for your pleasure?
u play u pay.
Old May 9, 2007 | 01:55 AM
VitViper's Avatar
u play u pay.
How's a couple of pulley's and a header cause the S/C to leak? Let him warranty the S/C without having to deal with bull____ excuses from the dealership.
Old May 9, 2007 | 01:59 AM
draxcaliber's Avatar
doesn't matter, if he took off the tamper evident pully cap, they will know.
Old May 9, 2007 | 02:15 AM
Whocares05050's Avatar
true story
Old May 9, 2007 | 02:39 AM
VitViper's Avatar
So put it back on
Old May 9, 2007 | 12:37 PM
articis's Avatar
That pulley cap wasnt even on the pulley when i got it back. I found it in the box of oem parts they gave back to me.
so can anyone help me?
Old May 10, 2007 | 11:44 PM
articis's Avatar
Can anyone help me? there is not much time left before i need to go to the dealer.
I thought the supercharger could hold up to 20psi, and It should not leak this early, I dont think its very good quality, it sounds like ____ and didnt notice much power gain from jst the s/c, so i added a few bolt ons to help it out.
Old May 10, 2007 | 11:48 PM
if it has a bad seal, maybe they will take care of it, because they have to prove that your headers and pully damaged it. not sure how easy it would be but anyway. try to replace the pully and the headers and see what they say.
also, how could you not notice a boost in 40 hp?
Old May 11, 2007 | 02:14 AM
O5_TRD_tC's Avatar
so u thought the s/c can hold up to 20psi, what about the motor?
Old May 11, 2007 | 02:24 AM
Garage1217's Avatar
They leak from a ____ty seal inside the shaft. Absolute crappy seal. I made a long winded post about the sc and all the guts and parts. Do a lil search Most likley the header coated or not killed the seal if you sit in traffic a lot, either that or the seal just died because it is garbage. Easily replaceable.
Old May 11, 2007 | 03:03 AM
VitViper's Avatar
Try 50whp. He must have a really horrible butt dyno.
Old May 11, 2007 | 06:22 PM
articis's Avatar
Thanks for the replies. I want to take to dealer but still need the heat shield so they dont blame the problem on no heat shield.
If they fix it I will get a blanket; if they dont I will search for the seal or a way to fix it on here.
Also the damn dealer lost my stock injectors and keep telling me they should be in the box. I keep saying they arent. I guess I will have to write a letter or something about the dealer.
help me with your heat shield if your not using it.
Old May 12, 2007 | 01:33 AM
emiller's Avatar
Depending on the dealer you had it installed at they may not care about the cap. Some dont bother putting it on and will admit it and let it slide that its missing.
Old May 13, 2007 | 01:29 AM
KiKaZ-tC's Avatar
apparently my dealer did not put on the pulley cap
Old May 13, 2007 | 01:33 AM
ziobep's Avatar
watching
Old May 15, 2007 | 02:28 AM
articis's Avatar
so no one has the heat shield?
Old May 15, 2007 | 02:33 AM
alot of us do, but we are currently using them...
Old May 15, 2007 | 03:32 AM
olaHalo's Avatar
any update on this other than you need the heat shield?
have you found out what caused the problem?
Old May 16, 2007 | 04:34 AM
articis's Avatar
no i havent found anything out, I was going to wait till i get the shield before i go to the dealer
