19 x 8 with 35 offset and tein springs ONNNNN!!!
Old May 17, 2007 | 02:12 AM
tunedis95's Avatar
Default 19 x 8 with 35 offset and tein springs ONNNNN!!!
....and the wheels are on 215/35-19s......so i was running these for a while....turns out they do rub whenever i turn....argh....anyone else have this problem.......and do ya get yas alighnment done after the tein springs......
Old May 17, 2007 | 02:17 AM
2_much_tc's Avatar
nope, i dont have this problem. and im running the 8.5's on the front and 9.5's in the rear with no issues. only time i rub is when i go on a dip at a fast speed. are you running s-tech's?
Old May 17, 2007 | 02:31 AM
tunedis95's Avatar
yea...s-tech's....
Old May 17, 2007 | 02:40 AM
davedavetC's Avatar
roll the fenders.
Old May 17, 2007 | 02:48 AM
2_much_tc's Avatar
i dont think you need to roll the fenders. i didnt have to and i have no issues.
Old May 17, 2007 | 03:02 AM
BuddhasTC's Avatar
is it ur tires rubbing...or the front end scraping...which will commonly happen with our car until they settle (the springs that is). Also, yes, you do need an alignment
Old May 17, 2007 | 03:07 AM
nebster's Avatar
ya man i'm not rubbing at all and i'm on 225/35/19's (for 2 more days)
Old May 17, 2007 | 06:36 AM
rolloutrs1's Avatar
roll the fenders.
x2
Old May 18, 2007 | 10:47 PM
tunedis95's Avatar
when i make a right turn the front passenger hits on the back corner of the wheel on the frame......
Old May 19, 2007 | 12:04 AM
RedLine_tC's Avatar
nice wheels
Old May 20, 2007 | 06:07 PM
vietxxguy's Avatar
looks good on that color
Old Aug 11, 2007 | 04:08 AM
LivNLo94's Avatar
looks good,
Old Aug 11, 2007 | 04:25 AM
maloy013's Avatar
nice rims too bad they rub...i also rub but only on the rear driver side but only when i hit deep potholes runing fast and im on trd drop on 19s
Old Aug 11, 2007 | 04:18 PM
CRUZtc8's Avatar
Default Re: 19 x 8 with 35 offset and tein springs ONNNNN!!!
what is the name of these wheels?
Old Aug 11, 2007 | 06:00 PM
tweak666's Avatar
sweet wheels!! are those TSW?
Old Aug 16, 2007 | 01:46 AM
deflaytedwayz1's Avatar
spacers my friend. since those are only 35mm offset they sit in further than the 45mm offset of the stock. get like a 5 mm space and you should be fine...disregard the fender rolling mentioned by others...that is why you should mention where you're rubbing. the spacers should fix your problem
Old Aug 16, 2007 | 02:11 AM
Tcguy85's Avatar
no that is all wrong. the lower the number the farther it sticks out. you have it backwards. 35 offset will stick out farther than the stock 45. his wheels are out 10mm farther than stock plus the rim being an inch wider overall, making them stick out half an inch plus the 10mm.
35 offset seems to work with a 7.5" wide wheel but you'll need 38-42 offset with an 8" wheel. this al depends on the drop though.
Old Aug 16, 2007 | 04:53 AM
HyPnOtIk's Avatar
Ok i was looking at Getting some wheels . I am lowered on Tein S Techs and i was told to get rims that are 18x7.5 ! All the rims i want are 18x8 so would those work if i get the 35mm offset or would i need a bigger offset . I am getting confused on if any 18 inch rims will work for me !
Old Aug 17, 2007 | 01:18 AM
yeah my bad on that one..totally spaced out on that one...i just haven't had a chance to get back to a computer to fix it...oops...thanks for fixing that in case anyone took it seriously.
Old Aug 17, 2007 | 10:59 PM
Cabana's Avatar
+35 and 8" wide = rubbing
