19 x 8 with 35 offset and tein springs ONNNNN!!!
....and the wheels are on 215/35-19s......so i was running these for a while....turns out they do rub whenever i turn....argh....anyone else have this problem.......and do ya get yas alighnment done after the tein springs......
nope, i dont have this problem. and im running the 8.5's on the front and 9.5's in the rear with no issues. only time i rub is when i go on a dip at a fast speed. are you running s-tech's?
spacers my friend. since those are only 35mm offset they sit in further than the 45mm offset of the stock. get like a 5 mm space and you should be fine...disregard the fender rolling mentioned by others...that is why you should mention where you're rubbing. the spacers should fix your problem
35 offset seems to work with a 7.5" wide wheel but you'll need 38-42 offset with an 8" wheel. this al depends on the drop though.
Ok i was looking at Getting some wheels . I am lowered on Tein S Techs and i was told to get rims that are 18x7.5 ! All the rims i want are 18x8 so would those work if i get the 35mm offset or would i need a bigger offset . I am getting confused on if any 18 inch rims will work for me !
