help me install a converter
Old May 21, 2007 | 10:03 PM
george_da_2nd's Avatar
Default help me install a converter
i need to put in a speaker wire to RCA converter in my car to hoook up my amp but were do i splice into to get the signal from my rear speakers. any help would be great!
Old May 21, 2007 | 10:14 PM
nebster's Avatar
well do you have one, or do you need to purchase one.
wiring them in isn't that hard, just a matter of finding the right speaker wire
Old May 21, 2007 | 10:21 PM
Daskid's Avatar
Since you just want the rears to work with an amp, this is what you can do:
1.) Splice the rear speaker wires at the back of the radio and connect the RCA conveter input to the speaker wires coming from the radio.
2.) Run an RCA cable to your amp.
3.) Run speaker wires from your amp back to your radio.
4.) Connect the speaker wires to the speaker wires which you cut going to the rear speakers.
5.) Double check your connection.
6.) Enjoy.
Old May 22, 2007 | 01:03 AM
i have everything and i know how to wire it up i just dont know what wires i need to splice so dose anyone have any pics or info?
Old May 22, 2007 | 01:11 AM
timmyinpajamas's Avatar
DeepSouth Scions
theres two plugs on da radio
the smaller plug got da rear speakers on it n steering wheel controls wires (if u have it )
i think its brown n white (left speaker)
and pink n yellow (right speaker).. go look
Old May 22, 2007 | 02:59 AM
can anyone conferm this?
Old May 22, 2007 | 03:18 AM
Daskid's Avatar
Try to use this:
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
Old May 22, 2007 | 03:38 AM
DeepSouth Scions
i believe that diagram the placement for the wires needed are right .. but the colors r not the same in our cars
Old May 22, 2007 | 03:39 AM
DeepSouth Scions
if u wanna wait till tom i can confirm it for you .. i gotta replace some rca cables tom anyways .. i am also using an converter
Old May 22, 2007 | 06:19 AM
MOBBIN_tC's Avatar
WRONG where the ____ did you get those colors from.
Old May 22, 2007 | 06:51 AM
MOBBIN_tC's Avatar
i think you're trying to hook up a high low converter to a factory radio. and also hook up a 4 channel amp? (thats what it sounds like) if so... here.....
speaker wire colors are
RF +/- = green/ blue
LF +/- = pink/ purple
RR +/- = red/ white
LR +/- = black/ yellow
so if you are trying to hook up a 4 channel amp with high low converter to a OEM radio...
Old May 22, 2007 | 09:03 AM
wow man thast perfect thank you!
Old May 22, 2007 | 12:38 PM
DeepSouth Scions
from the top of my head jerk .. but mines an 07 .. wen i did my friends 05 his colors werent the same
Old May 22, 2007 | 04:15 PM
oh i have an 07 too mabey your right? if you do work on it let me know if he he was righ tor wrong my amp dosent come in for another 3 days
Old May 23, 2007 | 02:56 AM
MOBBIN_tC's Avatar
no jerk prove me wrong!!! PROVE ME WRONG!!!!
LOL i do this ____ for a living!!! i know toyota colors by heart!....
they didnt change the wire colors on the 07 i installed on a 07 tc -_-
Old Jun 7, 2007 | 08:34 PM
got around to doing it and ther eis no black wir eanywhere!
Old Jun 7, 2007 | 09:28 PM
Daskid's Avatar
^^ There must be. Well at least for an 05...
Good luck!
Old Jun 11, 2007 | 04:07 AM
MOBBIN_tC's Avatar
for the 07... when youre doing that speaker its a brown wire now. so its paired up with a brown and yellow instead of the normal yellow black. thats the difference on the 07.
anywho.....
when you get the speaker wires around that are yellow and brown which are pinned next to each other you can take a 9 volt battery and tap one wire on the positive and the other wire on the negative you will hear a popping sound if its the speaker wires.
and i hope by now you figured it out
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
rcflyer15
Dec 5, 2014 05:15 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
