help me install a converter
i need to put in a speaker wire to RCA converter in my car to hoook up my amp but were do i splice into to get the signal from my rear speakers. any help would be great!
Since you just want the rears to work with an amp, this is what you can do:
1.) Splice the rear speaker wires at the back of the radio and connect the RCA conveter input to the speaker wires coming from the radio.
2.) Run an RCA cable to your amp.
3.) Run speaker wires from your amp back to your radio.
4.) Connect the speaker wires to the speaker wires which you cut going to the rear speakers.
5.) Double check your connection.
6.) Enjoy.
6.) Enjoy.
theres two plugs on da radio
the smaller plug got da rear speakers on it n steering wheel controls wires (if u have it )
i think its brown n white (left speaker)
and pink n yellow (right speaker).. go look
i think you're trying to hook up a high low converter to a factory radio. and also hook up a 4 channel amp? (thats what it sounds like) if so... here.....
speaker wire colors are
RF +/- = green/ blue
LF +/- = pink/ purple
RR +/- = red/ white
LR +/- = black/ yellow
so if you are trying to hook up a 4 channel amp with high low converter to a OEM radio...
RR +/- = red/ white
if u wanna wait till tom i can confirm it for you .. i gotta replace some rca cables tom anyways .. i am also using an converter
for the 07... when youre doing that speaker its a brown wire now. so its paired up with a brown and yellow instead of the normal yellow black. thats the difference on the 07.
anywho.....
when you get the speaker wires around that are yellow and brown which are pinned next to each other you can take a 9 volt battery and tap one wire on the positive and the other wire on the negative you will hear a popping sound if its the speaker wires.
and i hope by now you figured it out
anywho.....
rcflyer15
Dec 5, 2014 05:15 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
