turn factory fogs on when i want to?
Old Jun 4, 2007 | 09:22 PM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
Default turn factory fogs on when i want to?
how do i do that?! do i have to buy the JDM fogs, and if i wanted a JDM fog switch, how hard/could i hook it up instead? thanks!
Old Jun 4, 2007 | 09:26 PM
Amoxaphobic's Avatar
You would have to take the power wire and route it to a switch. This would prolly mean that you would have to route a new power wire because if it's factory, then it's already got a switch. And if it already has a switch then it's prolly being powered with the same power as your lights....
I am assuming you want to be able to turn them on without any other lights.
Old Jun 4, 2007 | 09:50 PM
mrfuzzy4's Avatar
right. or even just on with the running lights.... i want them on when i got my running lights on, so i figured might as well let them go on whenever i want.... is this impossible/hard/too much work for little payout?
Old Jun 5, 2007 | 12:34 AM
brnttoast's Avatar
It's possible, I haven't looked at the wiring of the factory fogs, but it is possible.
Old Jun 5, 2007 | 04:08 PM
THE_DON's Avatar
https://www.scionlife.com/forums/vie...hlight=inazuma
There's a couple of different ways... Using an extra relay is your best bet.
-THE DON
Old Jun 5, 2007 | 04:48 PM
typhoonorchid's Avatar
It might be illegal if they are technically considered "driving lights"
I know that's the case with my Bimmer.
you can run headlights and driving lights, or headlights alone, but not driving lights alone.
the electricals are wired that way to make it so you can't turn them on alone.
Old Jun 5, 2007 | 05:21 PM
Bossman's Avatar
I did this when I had my JDM fogs on my previous XB- It is possible, it is a _____ to do but once done it is nice to use as DRL's. I powered mine to the cigarette lighter. Use this as an example- this was the thread I used as reference for my re-wiring. Good luck to ya man! https://www.scionlife.com/forums/vie...548&highlight=
Old Jun 5, 2007 | 05:32 PM
mrfuzzy4's Avatar
its illeagle to have fogs and running lights on but not headlights? i dont really care, i dont think cops know.... thanks for the links! and thanks alot for the warning but ill take my bets; they will match my halos.
Old Jun 5, 2007 | 06:49 PM
THE_DON's Avatar
I run mine all day. Most cops don't know that rule.
The xB's lights are kinda high up, and white (when stock bulbs are used) so they don't really look like "fog lights". People who get tickets for running fogs during the day usually have the lower, smaller, yellow fogs... While still technically illegal, the xB's lights do look more like DRLs.
I've never had a problem.
-THE DON
Old Jun 5, 2007 | 09:10 PM
mrfuzzy4's Avatar
-THE DON
thats my feelings exactly. now my only q about that link to the wiring system is how do you enclude a relay/what does it look like and did all he do is remove the female wires, switch the spots and ground the newly added female wire? and what is the connector he mentioned? thanks!
Old Jun 7, 2007 | 02:26 AM
I didn't know that it was illegal to do that. I am not really sure that it is - Some GMs come with day time running lights... So my feeling is that fog lights can be considered running lights. Where did you hear that anyways? I'm not doubting you, I am just curious.
Acutally, I think the easiest way would be to not use a relay. Instead of using a relay, you can simply connect the black wire to the ground of your parking lights. That way, the only come on when your parking lights are on and when the car turns off, so do the fog lights.
But if you really want the relay, the Bosch SPDT Relay is the name of the relay. They said that you can get them at radio shack... at least Doc did. If you go there, just ask to see the relays. If you prefer to not shop at radio shack, you can always try to google it. I am sure it can't be much to ship such a small item.
If you need help with this, PM and I will try to walk you through it.
Old Jun 7, 2007 | 03:41 AM
raceronabudget's Avatar
whats the point of having a law like that anyway?
Old Jun 7, 2007 | 08:01 PM
4Horsemen's Avatar
Default Factorty fog light wiring
Does anyone or has anyone used the factory fog light wiring for after market fog lights? Seeing that scions are pre wired for alot of things.
bluemex
Oct 14, 2015 03:29 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
setpol
Feb 17, 2015 11:33 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
TheTripleC
Jan 4, 2015 06:46 PM
