Whistling noise - Just started happening
Hi. I've had my tC for a few months, I got it used with 31k miles on it, certified pre-owned with all sorts of warranties. It's an automatic transmission.
Just this week it started making this high pitched whistling noise when I accelerate. It starts as soon as I start accelerating and rises in pitch as the engine RPMs go up. It definitely sounds like it's coming from the engine. It started doing it while I was driving in a thunderstorm.
The car seems to be running fine otherwise; the check engine light isn't on, it seems to be driving okay. All the fluid levels are good.
I know it's pretty difficult to diagnose from a description, but I just wanted to know if you guys though I should bring it in to the service center and if you had any speculation as to what it is?
Originally Posted by tyscion
Is everything still stock? If there is a CAI, there's a good chance that is it.
The stock intake whistles anyway, just not as loudly. Check the intake piping before the air filter if it's stock, sometimes stuff could get caught in there. I'd be willing to bet it is the sunroof or the intake though.
I know next to nothing about cars though, so I have to admit, I have no idea how I would go about checking the intake piping. I'm trying to learn a little about mechanics but at the moment i'm a complete noob.
Okay open your hood and look to the driver side corner, you'll see black piping leading to a large black box right next to the fuse box. Right on the wall of the engine bay on the right side, the piping for the intake points down, check that piping for noise.
Originally Posted by darkohanzo
Check your stereo. Is it aftermarket? I had a bad ground in my stereo and it whistled with the rpms. almost sounded like a SC, was kinda cool. but not loud enough to be intimidating.
I found the intake pipe. It looks like it wasn't properly attached- only one of the two screws on it was actually holding it in place.
I can't really get it out to see if there's anything in it. Do I have to remove something to get it out?
I think you may have just realized the whistling. I had my tC for a few months and one day I heard the whistling. I thought there was something wrong just like you but after reading here I found out it was normal for the intake to whistle. If it is really loud then maybe you have a prob, but I bet its fine.
Originally Posted by Nychold
^^ Well, get it.
Never done this on my tC, but on my Beretta, you could remove the protective plastic shroud underneath the car, in case you dropped something. Which I did. Repeatedly.
Looks like I got myself into more work than I bargained for, which would be fine, but it's about 100 degrees out.
Originally Posted by Zweben
Actually, i'm not sure where the hell it went. I don't see it, and I shook the plastic shroud you're talking about and I didn't hear it.
Raiders757
Apr 14, 2015 10:26 PM
mw1957
Mar 16, 2015 06:00 PM
