Autosports & Technique
General driving and racing...
tips for drag strip
Old Jun 16, 2007 | 07:07 AM
badhabit_505's Avatar
Default tips for drag strip
any tips for dragging at the drag strip. i got a 2007 scion tc and i just raced it at the drag strip tonight.... my best time was 17.1. any tips on driving so i can get bettter times. also i noticed that i have a lot of whhel hop on the take off. any advice on the take off or any take off techniques i could try.... any advice would be greatly appreciated.... thanks
Old Jun 16, 2007 | 07:10 AM
its just the stock motor with no aftermarket parts just yet
Old Jun 20, 2007 | 03:11 AM
RSXaco's Avatar
don't pop the clutch, feather it
lower the front tires
lose as much weight off the car as possible
practice, practice, practice
Old Jun 28, 2007 | 05:27 AM
ignitionr34's Avatar
X2, 07's a lil faster that the 06's too. If you can master it u can hit low 15's. I was able to hit 15.3 on stock tires w/ removed axle back.
Old Jun 28, 2007 | 05:50 AM
draxcaliber's Avatar
well, on the motor trend review of the 05 scion tc, they got their times by revving to 2500 rpms, dropping the clutch and feeding the throttle.
now there are lots of ways make the car launch better, poly motor mounts, torque dampner, zpi engine limitor, wider and stickier tires with a ...isn't it softer sidewall tires better for drag? and then the more expensive part to add is an limited slip differential.
oh yeah, you have a manual right? not an automatic, manuals are a whole second faster.
Old Jul 7, 2007 | 04:54 PM
1tc4u2nv's Avatar
rev to 2500, drop the clutch, and work on your shifts. Once you master it that way then you can move up to 2700-2800 and feather the clutch. Leave the back tires at about 35psi drop the front to 26-28psi, and let them cool off after each run.Dont do burnouts before each run, that just heats up the tires and decreases their grip. But most of all, PRACTICE.
Old Jul 16, 2007 | 01:08 AM
RSracer's Avatar
The heat makes the tires grip better by making the stickier. Heat is good for the grip.
Old Jul 16, 2007 | 01:31 AM
1tc4u2nv's Avatar
on drag radials or slicks NOT street tires. The only benefit i would see with burning out on street tires is to remove any rocks or debris stuck in the threads.
Old Jul 19, 2007 | 07:23 AM
chillywilly638's Avatar
dam my car was stripped w/ axle back removed to and my best time was 15.9
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
MeDizzy
Oct 8, 2015 03:31 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
prescottn
Sep 13, 2015 09:04 PM
Bimfi
Sep 4, 2015 08:15 PM
