wastegate question
Old Jun 20, 2007 | 11:38 PM
bsptc27's Avatar
Default wastegate question
i was just admiring under my hood...lol and this caught my eye. is there supposed to be something there? its threaded and im not exactly sure. but ive been having problems with afr's and i wanna be able to eliminate every other possibility that might be the cause of it
[/list]
Old Jun 20, 2007 | 11:46 PM
Brett's Avatar
thats not your problem. all that is, is a thread for a vaccum hose barb. some boost controlers work by running vaccum to there.
Old Jun 21, 2007 | 12:38 AM
bsptc27's Avatar
ahh i see...thanks...mods can lock this if they want
Old Jun 21, 2007 | 12:39 AM
pollup's Avatar
im guessing because treadstone doesnt run any engine management with their kits. do you have a piggy back? is it emanage? if so reset your factory ecu. if not i would get a standalone or a piggyback.
Old Jun 21, 2007 | 12:41 AM
bsptc27's Avatar
no i dont have a piggyback...yet im hoping to get one soon. but im almost positive the high afr's are from an exhaust leak, i was just trying to eliminate all other posibilities.
Old Jun 21, 2007 | 12:51 AM
pollup's Avatar
high afr's from an exhaust leak? im not following how that would happen unless your leaking at the manifold maybe. lemme think about this.
Old Jun 21, 2007 | 12:54 AM
bsptc27's Avatar
its leaking from the downpipe to the s-pipe. the Wideband is attatched at the s-pipe
Old Jun 21, 2007 | 12:56 AM
Brett's Avatar
so your running a turbo with absolutley no engine management at all, and you think that an exaust leak is to blame for you high afr??
Old Jun 21, 2007 | 12:59 AM
bsptc27's Avatar
thats what im thinking, along with the installer. the kit is designed to run with no management, i know that its not a good idea, but im trying to get management and a tune asap
Old Jun 21, 2007 | 01:02 AM
pollup's Avatar
your wideband is too far away.. you really should have it in the downpipe near the factory wideband.
Old Jun 21, 2007 | 01:03 AM
Brett's Avatar
im gonna go out on a limb here and say that when you get an engine management of some kind, your afr's will be ok
Old Jun 21, 2007 | 01:04 AM
bsptc27's Avatar
i think so too....i wish it was located on the downpipe now too but i didnt install it and didn't know he was going to mount it on the s-pipe
Brett's Avatar
and why is that?
Old Jun 21, 2007 | 01:19 AM
vypa's Avatar
you will get a more accurated reading from closer to the engine IE downpipe.. i believe i've head the ideal is around 18inches downstream... and also i personnally had a very lean IDLE when the bolts holding the wastegate to the manifold vibrated loose causing a massive exhaust leak... but under WOT/partial throttle they were normal
Old Jun 21, 2007 | 01:27 AM
bsptc27's Avatar
durring idle im getting 15-16.5, WOT im at about 12.5-13. cruising im fine though at 14.6-15. im just staying out of boost till i an get this figured out
Old Jun 21, 2007 | 01:28 AM
Brett's Avatar
if you have a "massive" exaust leak then obviously thats gonna mess with your afr. but it really doesnt matter where it is located. mine is in the s-pipe. when you take your car to the dyno to get tuned, where does the tuner put the o2 sniffer? thats right, in the muffler. when he tunes your car he looks at what afr is on the screen, and not whats on your wideband. i know the directions say 18 inches, but really i doesnt mater that much.
now a pyrometer is a whole different story
Old Jun 21, 2007 | 01:34 AM
vypa's Avatar
yes a pyrometer IS a different story lol... but yeah mines in the s-pipe too, it was easier at the time lol... regardless i think the o2 sniffer they use on the dyno is probably more accurate than my AEM UEGO... wasnt tryin to start a peein contest tho
Old Jun 21, 2007 | 01:38 AM
Brett's Avatar
i dont think that your lean idle is caused by an exaust leak. i have the same thing with mine, but it only does it once the car has been running for a while. i think it has something to do with compressor surge or air temps.
Old Jun 21, 2007 | 01:42 AM
pollup's Avatar
i have the same idle, 14 to 16afr. now my wot is anywhere from 10 to 11.5. 12.5 to 13 is not good..
bsptc27's Avatar
yeah i understand what your saying....as soon as i start the car up its at 14.7-14.9 steady then once it warms up it starts going up
