Sheet Metal Intake....
Old Jun 22, 2007 | 01:26 AM
krazylowgsx's Avatar
Default Sheet Metal Intake....
I'm meeting up with a guy that used to make them for the DSM world. I had one of his intakes on my Eclipse and we're going to talk about production for the tc's. I was wondering if anyone had one built already and what TB they used. The Nitto 500hp TC has one, but they don't have pics on the site of the intake anymore. I want to get a feel as to how many people might be interested in these. Price won't be determined for awhile. but as an estimate.. the one i bought for my Eclipse was $700... and i've never seen a weld bead so beatiful!
the guys name is BJ.. as in.....
Old Jun 22, 2007 | 01:44 AM
Scott8's Avatar
I am watching.
Don't need one now, but you never know how far I may push the tC.
Old Jun 22, 2007 | 02:22 AM
huffy501's Avatar
me and my dad own a sheet metal fab company.....easy to make. good luck
Old Jun 22, 2007 | 06:21 AM
O5_TRD_tC's Avatar
watching...
Old Jun 22, 2007 | 08:04 PM
Scott8's Avatar
How easy? You're in AR and I am a 4 hour drive away from you to come pick it up
Old Jun 22, 2007 | 08:16 PM
Mr_Meaty's Avatar
I dont' think I understand what this is, where it goes, and what it's for.
Can someone explain? Perhaps show a pic of where it would go on our engine?
Old Jun 22, 2007 | 08:18 PM
vypa's Avatar
Its just a sheet metal intake manifold - it would replace the black plastic factory one, and basically if i understand correctly they are able to flow more air in boosted applications.
Old Jun 22, 2007 | 08:27 PM
huffy501's Avatar
id have to measure it up and then lay it out. so it would probably be about a 6-8 hr project and i could do it for less then 700.
Old Jun 22, 2007 | 08:30 PM
Scott8's Avatar
how much less?
Old Jun 22, 2007 | 08:50 PM
huffy501's Avatar
idk id have to measure it up to see how much material it will take to build it and it also depends on what material you want it made of.....Aluminum is rather pricey right now but it fluctuates daily. its definitely not 700 dollars worth of aluminum tho. I could draw it up on my laptop and do most the work on the CNC machine
Only 4 hrs away? where you located?
Old Jun 22, 2007 | 08:54 PM
Nychold's Avatar
Watching this... But wouldn't removing/installing the manifold on our cars mean pretty much removing the engine?
Old Jun 22, 2007 | 09:05 PM
Scott8's Avatar
I am outside Chicago, but my mom lives in Tennessee, so I pass through often.
Old Jun 22, 2007 | 09:06 PM
Scott8's Avatar
It would be a lot of work, but I eventually plan on doing the internals on the block and swapping out the head for a built head. So I would swap the intake at the same time.
Old Jun 22, 2007 | 09:39 PM
FIREDOG's Avatar
watching!!
Old Jun 22, 2007 | 10:30 PM
etsnet's Avatar
The intake manifold is on the opposite side of your exhaust manifold. So instead of in the front it's in the back of the motor. If you stand on the drivers side and look in the back of the motor you should be able to see it. If I remember correctly tha is the best way to see it.
Old Jun 24, 2007 | 02:07 AM
soros151's Avatar
I do not think u would have to remove the engine to get IM off the car.
Old Jun 24, 2007 | 06:48 AM
06SuperWhite_SoCal_tC's Avatar
I'd be interested. I think there is one already made for the tC's as well.
Old Jun 24, 2007 | 02:05 PM
soros151's Avatar
SL never got a dyno for that IM.
Old Jun 24, 2007 | 02:34 PM
Guru's Avatar
Magnus is working on one thanks to me. I sent them my spare one and it is a bit simpler since the injector bosses are on the head and not the intake manifold. Throttle bosy may have to be moved but really since this is a mod for the big boost guys, that shouldn't matter since some custom fab is in the cards for them anyway.
Old Jun 24, 2007 | 03:43 PM
Scott8's Avatar
I just want to see some dyno numbers from one of the Metal IM.
