do the '07's (tc) still have/use a reflash Map module?
Old Jun 22, 2007 | 11:16 PM
SpeedDeamon's Avatar
Default do the '07's (tc) still have/use a reflash Map module?
like the title says. i've had nothin but bad service from scion and have been mis-led and informed....which had lead me to doing my own research, and i see alot of topics about the "reflash Map module" and i never recieved a map module.....so i called the stealership, the tech on the phone said that the '07s dont need/use/or come with the module. Sorry to say, after my past experience i do not believe them....can anyone who knows about this please chime in and help me??
thanks for any help
Old Jun 23, 2007 | 02:07 AM
Wyatt_Herb's Avatar
Do you have a supercharger? If not then it is entirely unneeded. If you do, you still don't need one. The module is used by the dealership to reflash your ecu if you have the supercharger installed. Past threads might be referring to dealerships who did not have a the module yet when somebody was having a s/c installed and were attempting to charge the customer for the module itself.
Old Jun 23, 2007 | 03:46 AM
sorry i thought it was implied that id have a s/c(not tryin to sound like a dick, dont take it that way) yes i have a s/c and i have heard of the reflash tools(and some stealerships dont even have the tool!!) but im talking about the ecm map (reflash) module (and from what i've read, it cant be reused on other cars or on your own....but it's still needed(for some reason) because it has vin info linked to your car
Old Jun 23, 2007 | 12:37 PM
jetlounge's Avatar
no, this is what he is referring to.
the old flash system was hideous...one time only and required the service station to purchase a $500 tool. the automatics then required a 2nd flash on top of that which was supplied by the internal tis site.
on the '07 reflashing is done via TIS to limit the headache. Your ecm got reflashed, just via download not hardware.
Old Jun 23, 2007 | 04:22 PM
thanks for the reply
Old Jun 23, 2007 | 05:37 PM
06SuperWhite_SoCal_tC's Avatar
should be in your car, unless they have a different way of Reflashing for 07 tC's?
Old Jun 23, 2007 | 06:08 PM
jetlounge's Avatar
no. read 2 posts above.
Old Jun 24, 2007 | 06:52 AM
I know what that is. Im asking if hes talking about this ^ It's for "future service needs" and they told me to leave it in the car somewhere, because it might be needed at a later date. Dunno what it does... but it's s/c related.
Old Jun 24, 2007 | 07:00 AM
SquallLHeart's Avatar
NOPE!!! there's no more crappy data module! (go TRD!)
it's all done using TIS and Toyota's current diagnostic and scantools... you're safe... you don't need one of those crappy things.
Old Jun 24, 2007 | 07:07 AM
Ah, so it's a Data Module, so if say you blow/damage something they can look back at last running conditions, like a "black box" ?
Old Jun 24, 2007 | 07:45 AM
no.. the module that you pictured contains the new mapping data that needs to be tranferred into the ECU..
that's done using the now obsolete POS data transfer tool which the dealership needs to special order to have
(they are alloted to only be able to buy one as well)
in case that you need a new ECU, you have that module to reload the data into the new ECU.... hoping that a dealership has that transfer tool that you'd need... it's crap really..
new way is better.
Old Jun 24, 2007 | 02:04 PM
jetlounge's Avatar
that's not entirely correct.
the ECM reflash module on the 05/06 is ONE TIME only. If you get a new ECM or have a failure that requires a reflash you need to get another unused map module.
during the reflash process, the map module itself is programmed as well.
Despite the verbiage on the little map module box and in the s/c instructions...you do not have to leave that paperweight in your car...it is useless to you after it has been used.
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
sethmskinner
Aug 4, 2015 02:38 AM
roadrunnergt
Jul 20, 2015 05:25 AM
