How's this for brakes?
Old Jun 24, 2007 | 11:26 PM
dieselstation's Avatar
Default How's this for brakes?
Old Jun 24, 2007 | 11:47 PM
Dakine's Avatar
Concept in Motion Crew
looks like a good deal. where do u get this rotor? im in need of a new one also.
Old Jun 24, 2007 | 11:53 PM
the above is at http://www.sciongeneration.com/
the only thing iffy is do i want the Axxis Ultimate pads which are kinda dusty, or Hawk HPS pads. And i would like Stop-Tech rotors instead of powerslot rotors also.
Old Jun 25, 2007 | 01:17 AM
Spect2K3's Avatar
I personally am not a fan of stainless steel lines. They only improve brake pedal feel, not stopping distance or brake fade. The fact that the tC has a brake booster I think takes the essential purpose out of the steel lines as they would be used to modulate brake feel in the pedal, yet with a booster, you can't do much modulation. As long as you know that, go for em.
Also, the ultimate pads are pretty harsh on the rotors. They will put major stress on the rotors and be very dusty. Really only necessary on the track IMO. BUT, you will like the setup that you have above regardless of what I have mentioned.
Old Jun 25, 2007 | 07:53 PM
The_Instigator's Avatar
Axxis Ultimates are NOT harsh on rotors and are NOT to be used on track. They are a high performance street pad that relies mostly on adherent friction as opposed to abraisive friction which is why a thorough bed-in procedure is imperative to their optimal performance.
For the brake lines, they will still help modulation and feel even with a booster since the issue is flex in the factory rubber lines. Decreasing the amount of compliance in the system will help to improve responsiveness and redue the time it takes for the pressure from the booster to the calipers themselves. Just about every car on the road these days uses a booster and most see improvements from SS lines, especially as the car gets older and the rubber lines deteriorate.
Old Jun 25, 2007 | 11:04 PM
thanks Instigator! your name has come up a lot on SL as a very knowledgable guy. So i might as well ask you for your recommendations.
what would you do (as in brands) for rotors/pads/fluids, and would you do ss lines also?
Old Jun 25, 2007 | 11:23 PM
Well, I will always recommend StopTech since its where I work but after using most of our prodcuts myself I do have good knowledge of them.
For a daily driven car, dont worry about spending extra on the Motul brake fluid. Something like Valvoline SynPower will hande aggressive street driving and still be resistant to boiling and cost much less. For pads, the Axxis Ultimates are great but can be a little noisy and dusty. Recently we installed new lines and pads on KINGxOFxSKA's tC. We used StopTech lines, Valvoline SynPower and pads offered by our parent company Centric Parts called PosiQuiet Ceramic. Pedal feel improved noticeably and bite was better than stock with a higher temperature range. I dont remember what my tC felt like with stock pads or Axxis Ultimates in the stock calipers but I was impressed with the feel of the PosiQuiets after a bed in cycle.
Im sure if you PM KINGxOFxSKA, he will let you know how its all working out since he has had the parts on for a few weeks now.
Old Jun 25, 2007 | 11:37 PM
can i buy stoptech stuff directly from stoptech? or do i have to go through one of your retailers?
Old Jun 26, 2007 | 12:06 AM
We no longer do direct sales but any of our resellers can help you with an order.
Old Jun 29, 2007 | 08:47 AM
Racersky's Avatar
Just to let you know hawk brake pads aren't really good to the ears.....they will make a lot of noise when your stopping but then again they stop you pretty much on a dime. IMO the noise just shows how good of a brake pad it is and how well it's stopping you.
Old Jun 29, 2007 | 01:48 PM
BrEaK_AwaY's Avatar
erik FTW with brake knowledge. he helped me alot with my rotora bbk install. so take his advise, he wont steer ya wrong.
erik... my brakes are bitting good, but i think i need to re-bed them. is it ok do do that after ive been driving on them for a few thousand miles now? i dont see why it would hurt... but would it help?
Old Jun 29, 2007 | 07:49 PM
You can just about always re-bed. The only time you should shy away from it is if your pads are very worn..and in that case you should just buy new pads anyway and bed those in instead.
Old Jun 29, 2007 | 07:51 PM
BrEaK_AwaY's Avatar
kool. thanks man. if the roads weren't wet id do it on my way to the dealership for work tonight.
Old Jun 29, 2007 | 07:57 PM
amdforever's Avatar
Sry, brake noob here, what do you guys mean by "bed-in" on the brakes? Is that similar to the breakin period or something?
Old Jun 29, 2007 | 11:33 PM
mattieg's Avatar
watching... want to know more about breaks as well. Really want zinc plated rotors.
Old Jun 29, 2007 | 11:43 PM
Spect2K3's Avatar
The bed-in process is a process that is usually overlooked when installing new brakes. Check out www.stoptech.com for details on how to bed-in the brakes. It basically is so that the pads lay nicely against the rotors when brake pressure is applied.
Old Jun 29, 2007 | 11:53 PM
amdforever's Avatar
ah, cool, thx Spect
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
