tire pressure light?
Old Jun 28, 2007 | 05:13 PM
H-town_hero's Avatar
Default tire pressure light?
my tire pressure light is on
and i checked all my tires and they are fine
i dont kno what to do
Old Jun 28, 2007 | 05:21 PM
mcheng08's Avatar
you might want to re-calibrate the wheels again
Old Jun 28, 2007 | 05:22 PM
how would i go about doing that?
Old Jun 28, 2007 | 05:25 PM
BrEaK_AwaY's Avatar
you mean balance?
and no your fine. if you checked the pressure in all the tires and they are fine. then open your glove box, and hit the reset button for your TPS and your good to go
Old Jun 28, 2007 | 05:26 PM
Mightygnu's Avatar
Once you reset the TPS.. If it comes on again, then balance those bad boys!
Old Jun 28, 2007 | 05:28 PM
BigMURR's Avatar
Does it really detect whether or not the tireds need balancing? becuase mines always on I've just given up on turning it off.
Old Jun 28, 2007 | 05:29 PM
ya like all my tires are at 29psi there supposed to be at that right?
Old Jun 28, 2007 | 05:32 PM
BrEaK_AwaY's Avatar
the TPS = Tire Pressure Sensor. It runs by a wire that detects the speed (rotation) of the tire. If you have less pressure in one tire, compared to the others, the light will trip because the system is detecting one wheel moving at a different speed then all the others.
it can also trip if the that sensor wire has been damaged.
so if yours keeps tripping murr, and all your tires have the same pressure in them (i like to run 32 or 35), you have a problem with your system, and a wire was probably damaged.
Old Jun 28, 2007 | 05:33 PM
BrEaK_AwaY's Avatar
29 is low... bump them bad boys up to between 32 - 35.
Old Jun 28, 2007 | 05:35 PM
BigMURR's Avatar
well thanks for the response I will go get that and my sunroof checked out while I'm still under waranty
Old Jun 28, 2007 | 05:37 PM
BrEaK_AwaY's Avatar
not to get off topic. but whats wrong with your sunroof?
Old Jun 28, 2007 | 05:38 PM
rgeezyinTC's Avatar
if u have a 2007 and have aftermarket wheels thats your problem right their!!!
o ya im gonna try adding some more pressure to them
because i got 29psi after driving for an hour on a really hot day
so its prob lower than that right now in my garage
Old Jun 28, 2007 | 05:39 PM
BigMURR's Avatar
The infamous sticky wind deflector.
Old Jun 28, 2007 | 05:41 PM
Shocker's Avatar
http://home.cfl.rr.com/icdedppl/faq.html#c15
Section C #15
jaxtcracer's Avatar
what year tC do you have? if it's an '07, the TPMS are built into your valve stems. consequently, if you have aftermarket wheels, your TPMS light will ALWAYS be on unless you transferred the valve stems to your new rims. if you have and '05 or '06, the TPMS reads off of ABS. if you're still on stock wheels, try pressing the reset button inside the glove box and if it still doesn't work, even after the tires are at the recommened PSI, i'd say call the dealer and have them look at it.
Old Jun 28, 2007 | 05:42 PM
BrEaK_AwaY's Avatar
rgeezyinTC... your 100% wrong. if you know nothing about the system... why reply with false information?
and murr i figured. all the dealer is going to do is clean the track and re-lubricate it. but its free for them to do it under warranty, so i agree with you gong back to them and making them do it. haha
Old Jun 28, 2007 | 05:46 PM
BrEaK_AwaY's Avatar
very good point. i forgot to ask if it was an 07. but i believe he has factory wheels.
there is a way to trick the TPMS with newer cars that have aftermarket wheels that dont have enough room for the TPMS though. It wont be a working system, but it will turn the light off. if you put all the sensors in your spare tire, all the sensors will read the same tire pressue, so your light will go off. but like i said, it wont be a working system.
Old Jun 28, 2007 | 06:05 PM
jaxtcracer's Avatar
ahh now there's a good idea. unfortunately that would have cost me an extra 80-100 dollars to get my old tires dismounted from my stock wheels, so i passed it up. maybe i'll just take apart the gauge cluster and kill that specific LED
Old Jun 28, 2007 | 06:17 PM
BrEaK_AwaY's Avatar
you could do that too. haha
