ANY TIRE PRESSURE SENSOR RELOCATE TO NEW RIMS STORIES?
looking to get some cool 18" for my 08" tc but was wondering where to go in Los angeles county. Anyone get new rims/tire and suscessfully transfer their tire pressure sensors onto their new rims and no warning light issue, pls help?
how can you li8ghts not come on if you dont have tire sensors? if they dont come on, than how do you know if the sensors were ever transfered over correctly?
Any how, I had my sensors done at americas tires they said they just had to swap out the valve stems to the new tires because the sensors were attached to them?
anyhow, I have no low air pressure light, so Im assuming it went alright?
Originally Posted by SquallLHeart
wherever that can mount your tires can do them.
just transfer the sensors, and you'll be fine.
on 08s the TPMS is too large to fit with low profile tires. in thie case, you remove the sensor, and place them INSIDE of the spare tire. reason for this? because every sensor will read the same pressure, there for making you tire pressure warning light go off. Now the system wont be effective because its not reading the pressure on the tires on the car itself. but it tricks the system into thinking every tire has the same amount of pressure
Yeah, just have a shop deflate the spare, take the tire off, toss them in the tire, put it back on the rim, pump it up with air, then do the reset instructions in the manual for the air warning system and you will be good to go.
Hmmm, you know what, I wonder if you can find one of these http://www.marathonind.com/Merchant2...136506FFsm.jpg that is small enough but will be able to hold say 15lbs of air and the sensors in it? You would be able to use your spare and have no light
sure you could. but where are you gonna store it? haha
Hmmm well if the 08's are thicker and the person def. wants the TPMS to work right on their rims, they could just by the 07 sensors right? I know they have to be programmed into the monitoring system but I think the dealership can do that. Might be a tad expensive but if they want to keep that functionality and use their lowpro. tires then that seems like that would be what they need to do.
um . if the 2008 monitors do not work with low profile tires , WHY ARE THEY ON THE CAR ?????? Please enlighten us as to how stupid Toyota is . And thanks in advance
And to people that understand about this , I DO have to have the air let out of my new tires ( aftermarket ) to put these in correct ?
