Help with install.
Old Jun 30, 2007 | 02:26 AM
sv650's Avatar
Default Help with install.
So I desided that I needed to upgrade my sound system with an amp. I already have in the car a alpine 9856 deck and focal 165 A1 components in front and 165 CA1 in back. So I got a Rockford Fosgate P450.4 Punch 4-channel 450W Amp and the appropriate 4g wiring kit. I do the install and the thing says it has power but there is no sound coming out the speakers. I checked all the conections and they all seemed good. I played arond with all the settings on bot the deck and amp (btw the rockford amp manual is not very helpful to say the lest). What do I do now? Should I just go to an install place and pay the 60 bucks for them to do it over again? Any ideas?
Old Jun 30, 2007 | 04:05 AM
Dr_Isotope's Avatar
Take a speaker with a length of wire attached and try it on each output terminal on the amp. IF you get sound, the inputs on the amp are good, and you have a speaker wiring problem. If you get no sound, you likely have a source wire problem.
Basic troubleshooting. Start at the amp and work your way forward.
Old Jun 30, 2007 | 04:14 AM
sv650's Avatar
Thanks for replying doc. So I tried this and got nothing out of the speaker. I have a front speakers and back speakers set of RCAs going from the deck to the amp and I checked the connections of both of these cords and could not seem to find anything wrong. When I unplugs all the RCA cables from the amp the power light on the amp went off so it knows when the cables are hooked up... I wish I could figure this out it's rather irritating. Any more thoughts?
Old Jun 30, 2007 | 04:24 AM
Dr_Isotope's Avatar
To my knowledge, the amp should power up whether the RCAs are attached or not. This leads me to believe that the RTL isn't turning the amp on as it should be, or there is some other issue with the power/ground wiring to the amp.
Old Jun 30, 2007 | 04:53 AM
sv650's Avatar
I am sorry but what is the RTL? So I should check the power wires?
Old Jun 30, 2007 | 09:24 AM
Adidude's Avatar
RTL= Remote turnon lead. Should be blue or blue/white on the HU
dgm458
Scion xD Drivetrain & Power
Aug 24, 2015 04:44 AM
epyellow
Scion tC 2G Forced Induction
Jul 3, 2015 07:05 PM
halosinfire
Jun 10, 2015 05:21 PM
Prolific998
May 1, 2015 06:38 PM
Toy_xbox
30
Feb 16, 2005 09:28 PM
