A/C STOPED BLOWING COLD AIR Help!!!!
Old Jul 2, 2007 | 04:03 PM
EZ-BAKED's Avatar
Default A/C STOPED BLOWING COLD AIR Help!!!!
ok so my a/c stopped blowing cold air this weekend any ideas I checked most all the fuses and nothing. Help please its going to be real hot this week.
Old Jul 2, 2007 | 06:30 PM
g0nk's Avatar
take it in to get it looked at, i wouldnt mess with the a/c system.. might just need a recharge
Old Jul 2, 2007 | 07:28 PM
itlstl13's Avatar
Default a/c
did ur air just stop blowing cold as asoon as u turn it on or is it after u car sits for like ten minutes and then u try to turn it on and its only hot... if its the second one it happened to my 05 box too and i took it to the dealer and they had no f-in clue what was wrong with it... first time they said it just over heated and it should be fine.. three times later with the same problem they finally swapped out my blower and its been fine since for the most part... i noticed that it happens when the car is idle for about 2o mins with the air off and then when u turn it on ur f-ed becasue then ut doesnt work.. just thought id throw my 2 cents in
mike
Old Jul 2, 2007 | 07:32 PM
EZ-BAKED's Avatar
iT just never gets cold now. started on friday. worked fine one day the next it wont get cold gust blows warm air.
Old Jul 2, 2007 | 11:34 PM
andrewdustin's Avatar
i would take it in and see if it needs to be recharged. mine throws out moderately cold air on moderately warm days. it is a small system so you can ask for too much, most likely it just needs the freon changed out.
Old Jul 3, 2007 | 12:50 AM
Metro273's Avatar
Hey EZ, if it just started, it's possible that while you were driving, some vehicle in front of you, kicked a rock thru your AC condensor, since it's so exposed to the elements.
As far as people saying you need to just recharge it, NOPE! If it needs a recharge, it's cause there is some sort of leak in the AC system.
Let us know what the dealership finds...
Old Jul 3, 2007 | 05:02 AM
pollock3s's Avatar
Just hope it's not the compressor. Remember my box was only three weeks old and the compressor internally came apart and there was definetly no cold air coming from the vents.
Old Jul 3, 2007 | 07:20 AM
OldYeller's Avatar
Yeah--my first thought was the compressor also--let us know what you find.........
Old Jul 6, 2007 | 09:34 PM
EZ-BAKED's Avatar
It is the condensor tryed rechargin it and found the leak but the leak is @ the top not the bottom where im missing parts.
Old Jul 7, 2007 | 01:38 AM
xBster's Avatar
glad to hear you got it figured out, nothing worse than a/c that doesn't work when it's hot...
Old Jul 10, 2007 | 12:09 AM
EZ-BAKED's Avatar
OK so I took it in today to have them check it out they told me my compressor clutch went out and is stuck on so thats what blew the condencer and my woranty is up so its all on me. a 2004 with 47,000 miles sigh.
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
miguelishu
Mar 9, 2015 02:38 AM
AxRxP
Jan 25, 2015 08:40 PM
snart
Feb 3, 2004 08:56 PM
