stupid AUX cords
Old Jul 5, 2007 | 01:51 AM
dessilu's Avatar
Default stupid AUX cords
I don't know whats going on but I have gone threw at least 6 aux cords. Even the ones that cost me 25-30 dollars.
After awhile they start screwing up and only playin on the passenger side speakers. I have to play around with the cord or hold it a certain way for it to play on both sides.
I don't know if it's the arizona heat or they are just poorly made. Anyone else have this issue?
Old Jul 5, 2007 | 01:54 AM
Tcguy85's Avatar
i didn't have that problem. i don't use it anymore now though.
Old Jul 5, 2007 | 03:03 AM
carbontc's Avatar
I could never get them to work right. Out of the box it was playing only on the left side. Maybe it's the wiring in the car?
Old Jul 5, 2007 | 03:34 AM
redwing634's Avatar
I bought a Bose Aux cable from ebay and have been using it for over a year with no problems; bought the same one for my gf and shes had no problems either..
Old Jul 5, 2007 | 06:55 PM
Keeshwah's Avatar
The cables can't go bad without something else going down with it. Try opening up your console and making sure everything is nice and tight, especially the plug that goes into the arm rest. If you want some pics of what to look for I can try and get you some.
Old Jul 5, 2007 | 06:56 PM
Keeshwah's Avatar
I hope you didn't pay too much.
Old Jul 5, 2007 | 07:05 PM
redwing634's Avatar
nope, it was like 5$ each at most? cant remember it was awhile ago lol. But no they werent expensive
Old Jul 5, 2007 | 07:14 PM
SeanstC's Avatar
yeah 5 bucks at walmart.. mine works fine.. even the part thats flatter than a pancake becuase of the console lid hehe
Old Jul 5, 2007 | 07:34 PM
ADRdesignCo's Avatar
get a multimeter and test it for continuity (tip to tip, ring to ring, sleeve to sleeve).. also try a diffrence input source to see if you get the same problem. i used a cheap cable and it worked just fine for as long as i used the stock deck. if you get continuity all through the cable just fine, then you even swapped input sources, and you still have the problem then its definately the wiring.
Old Jul 6, 2007 | 03:29 PM
sciontC's Avatar
DeepSouth Scions
I bought one at best buy for $6. Had mine for about a year and it started doing that after 5 months. But as long as I turn the aux cable and avoid one area it will play both speakers. My aux prong somehow got bent though, i figured that was the reason.
Old Jul 6, 2007 | 04:08 PM
tcridinclean's Avatar
1UP Crew
i got mine for $20 from best buy, its from monster cable so it works pretty good, its a nice thick cable and ive had it for a year and no problems
Old Jul 7, 2007 | 12:03 AM
sciontc_mich's Avatar
doesn't sound like it's the cable. sounds like the aux connector in the console is faulty. Causing the connection to go bad.
You should've gone to radio shack and got a cable (1/8" stereo to 1/8" stereo, or 3.5mm to 3.5mm stereo, same measurement), that way they'd help you if you brought it back, and they could've tested out the cable, unlike other places.
So do that, or go to the dealer and they'll have to replace the aux connector in the console, i bet that's what it is.
CrowJenkins
Oct 9, 2015 10:47 PM
Spitfire23
Scion tC 1G ICE & Interior
Sep 8, 2015 03:31 AM
BlingSlade
Sep 5, 2015 08:52 AM
Chrono
Aug 25, 2015 05:59 PM
RokGoblin
Aug 11, 2015 05:24 PM
