Turbo ? lag related
Old Jul 8, 2007 | 02:55 AM
TuningIsLife's Avatar
Default Turbo ? lag related
Ok so I was experimenting with my setup which was running outragously rich like probably a 12.5:1 a/f. So I had in there 370cc injectors with a greddy e-manage which was supposedly tuned for them. So in an effort to lean it out, I switched out the injectors to the stock ones and disconnected the e-manage. Now it is running at about 13.5-14.5a/f @ 6psi. The idle is much better, the a/f is better, but the problem now is that it is very hard to boost. When I reach 3000-4000 RPMs the boost guage hits 0psi and the car bogs down and does not boost, however if I get past that point, at a higher RPM it boosts just fine.
Any Idea what would cause this? It boosted fine previously with the upgraded injectors and e-manage installed.
Old Jul 8, 2007 | 03:01 AM
draxcaliber's Avatar
i don't know...leander a/f mean less exhaust gas to spool the turbo and it doesn't boost until it reaches a higher rpm where there is more exhaust gas to spool the turbo.
so you need it running richer to make more boost faster, kind of like the antilag/misfiring system. the system would intentionally misfire to help the turbo spool faster. your car is tuned to run richer to spool faster maybe?
Old Jul 8, 2007 | 07:48 AM
it was supposed to be tuned slightly richer for safety reasons. While driving I noticed that it would bog down around 4000 rpms but if I down shifted from 5th to 4th over 4000 rpms it would boost fine. Also the unburnt fuel smell is gone, but it still throws a p0172 (excessively rich) which could be caused by the fouled o2 sensor.
Old Jul 8, 2007 | 03:50 PM
blown_xa's Avatar
12.5afr is good, i run 12.0 all arcross @ wide open throttle, cruising and normal acceleration i read around 14 afr
Old Jul 26, 2007 | 04:56 AM
symiansix's Avatar
do you think maybe the emanage is tuned for those specific injectors? i think the emange can control the injectors and tune them for duty cycle. but 12.5 afr isnt that rich like blown_xa is saying
Old Aug 4, 2007 | 06:05 PM
Whocares05050's Avatar
Wow. If you boost anything ABOVE 13, say goodbye to your motor after a little while. You want to be around 11.2 - 11.8 WOT to have an awsome SAFE tune. TOO RICH is in the 10.2 area. You want the car to idle and cruise around 14.
tckid21
Jan 9, 2016 09:19 PM
Scionxa180
Sep 24, 2015 03:51 AM
brett561tc
Sep 15, 2015 06:33 AM
kmouse64
Sep 4, 2015 01:11 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
