Fuel Rail???
Old Jul 8, 2007 | 06:11 AM
kocho333's Avatar
Default Fuel Rail???
Any body know of a aftermarket or larger fuel rail available....or even if there is an upgradable fuel damper.... cant stop a fuel leak!!
KOsta.
Old Jul 9, 2007 | 03:43 AM
malibuboy54's Avatar
are you inectors squirting out oil? thats the first place to look at for gas leak.....make sure that all o ring are seated properly, and i good condition....this is most likely the cause of your problem....
Old Jul 9, 2007 | 05:19 AM
kocho333's Avatar
no no no prob there just need a larger fuel rail but i guess custom is the only way to go....
Old Jul 9, 2007 | 05:35 AM
i would say custom for sure.....just curious, why do you need a larger fuel rail to stop a gas leak from that area.....my buds and I did a supercharger install for another guy, and he had a gas leak like dumping gas on the ground....turned out it was the o ring seals on the injectors.....
Old Jul 9, 2007 | 05:36 AM
Mightygnu's Avatar
usually its the o-ring not sitting right, but still I don't see the reason for a larger fuel rail?
Old Jul 9, 2007 | 06:52 AM
TunedtC's Avatar
Yeah check for leaks thoroughly first.
Old Jul 9, 2007 | 11:31 AM
toyota_scion_tc's Avatar
Question why do you need a larger fuel rail? I am pretty sure Zpi and Dezod are using the oem fuel rails. If you want more pressure and volume get a 255 LPH fuel pump.
Old Jul 9, 2007 | 04:09 PM
Mightygnu's Avatar
that is correct!
Old Jul 9, 2007 | 06:01 PM
yeah, cause usually the primary place for gas leaks around there are from the injectors.....it is really important to have the seals sit right, etc or it will squirt oil, and pool in the engine bay.....i doubt that it is your fuel rail, since the injectors squirt out looking like the rail is leaking.....
Old Jul 9, 2007 | 08:43 PM
Simplyscion's Avatar
Team No Limitz
yea, kosta, hit up my cell...not sure what your up to now that you need a fuel rail hahaha...gimme a shout when u get a chance
Old Jul 17, 2007 | 04:53 PM
kocho333's Avatar
lol nah guys its nothing like that... ok i pulled off the supercharger and reset a junked ecu. the reset ecu is running a crazy map...my car is keeping up with g35 coups the new ones and with just a short ram intake... i know theyre slow but...a basically stock tc>??? neway for some reason this map is dumping fuel and the damper cant hold it with the stock injectors...its backing up.(damper is the piece that is bolted to the fuel rail and the fuel hose. metal tank with a plastic cap) its leaking from both ends of that...and took time for it to start leaking. i tried putting in the supercharger injectors but lost the power...and after a while the engine started knocking...to rich i guessed, put back the stock still leaking. so i figured bigger reservoir for fuel no leak....
Old Jul 17, 2007 | 10:24 PM
Figure out some way to have a return fuel line into the tank and you won't have that problem.
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
