anyone in NJ area with experience in exhausts wanna make $$$
Old Jul 9, 2007 | 03:01 PM
phoenix_2o1_rising's Avatar
Default anyone in NJ area with experience in exhausts wanna make $$$
due to my "friends'" inability to help after several dates to help and no-shows.... is there anyone in the nj/ny area that would wanna help me install/troubleshoot my exhaust install... would pay for your time/services via $ or lunch or parts or whatever... i just need this exhaust done ASAP... it's on but is making a butt load of noise and cant tell if its vibration... leak... both... poor choice of parts... etc....
fyi...
it's megan header -> invidia s-pipe -> megan mid-pipes -> megan drift spec axle back... all parts used, and bought from fellow scionlife ppl
thanks ahead of time guys/girls
Old Jul 9, 2007 | 06:33 PM
malloynx's Avatar
if your close to philly, hit up mufflex... they do awesome work and will not kill you on the bill. there like a midas but more for the tuner at heart
Old Jul 9, 2007 | 06:35 PM
Big_Bird's Avatar
you should hit up a muffler shop for that trouble shooting. If you dont want to do that, i'd be happy to help, but a trained eye, would be way better.
Old Jul 9, 2007 | 09:23 PM
it just sucks, cause after i let off the gas i hear it sorta back fire and rattle the exhaust... any ideas where this might be coming from and why its happening...
Old Jul 9, 2007 | 10:10 PM
Importspeed's Avatar
if it is making a loud raspy sound when you press on the gas then buddy you need a resonator install that and your problems will be gone.
Old Jul 10, 2007 | 12:42 AM
BZinn1's Avatar
Backfire when you let off gas can be the exhaust has a leak.......double check your gasket seals..........with all the pieces you put on it is gonna be loud and raspy........need a resonator.........but first check for leaky gasket on the pipes........
Old Jul 10, 2007 | 02:58 AM
as far as a resonator goes... theyd take off the first piece of the mid pipe and take off the (i think) 18 inch one and replace it with lets say a 30? right?
Old Jul 10, 2007 | 04:42 PM
crackl0vesyou's Avatar
you u have tools i can help u or atleast try to help u out i had alot of troubles with my exhaust with leaks and loud noises
Old Jul 10, 2007 | 05:31 PM
yea i think i got most of the tools i need, when would work for you, i work in that area during the day, well actually guttenburg but i drive thru there to get to work, and did you ever get anything settled with those tickets and stuff?
Old Jul 11, 2007 | 04:33 AM
eh soon on the 12th ill have an update on it on my orignal post umm im booked at work till the 19th but im sure i can get in some time in between really quit
does ur exhaust sound like your running straight pipes ? really loud
eh soon on the 12th ill have an update on it on my orignal post umm im booked at work till the 19th but im sure i can get in some time in between really quick
Old Jul 11, 2007 | 01:26 PM
that sucks, good luck with that
thats one of the issues lol, i also have a small leak i have to locate and other ideas and also rattling, so i have to re-check all my gaskets and such, but it suckls when 1-you're car is lowered and a regular floor jack wont slide under and all you can do is raise it with scissors, and 2-even on scissors youre too fat to work safely under neath lol
Old Jul 11, 2007 | 04:20 PM
my car is pretty low to so dont worry u use ur oem jack that comes with the car and then us another jack once u raise it up high enouhg
Old Jul 11, 2007 | 08:53 PM
ok, so i had a friend come over today, we got the rattle problem settled, it was both a leak and loose connection... i put on an anti-fouler to move the o2 sensor and just from the placement of the bung, i could not tighten it down fully so it came loose and therefore was my rattle and leak... now i have another problem... my o2 sensor isnt reading properly, its actually reading too low... i dont have a CEL but at the same time its reading too lean on the ratio that my n2o wont kick in... anyone have any ideas... my friend told me that TRD makes a wide band o2 sensor, anyone know anything about this?
Old Jul 11, 2007 | 09:03 PM
ack154's Avatar
Moved to Northeast for some NJ people to see...
Old Jul 11, 2007 | 09:33 PM
PhillyCamoBox's Avatar
hmm my brother did his full exhaust and used the anti fouler and had no problems... he used obx heads/s-pipe and Ark Cat Back Exhaust
DJ_FroZone
25
May 30, 2019 07:17 PM
meowtc
Mar 5, 2015 02:28 AM
scsteven
Jan 25, 2015 01:06 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
