06 Greddy supercharger long-run reports?
i know that there is things that have to be re-wired on this supercharger due to the fact that it is meant for the 05 model.......what im trying to see is how many of you 06 guys have them on the box? how long have you had them on your box? has there been any issuses with your boxes? do you recomend other 06 boxes to use this or go w/ another supercharge like the blitz?........................thanx for you time guyz.......
Please see my post on the subject:
https://www.scionlife.com/forums/vie...690&highlight=
I have had a total of three problems since I installed the supercharger.
#1 - shorted engine harness ECU power to starter relay. This was my screw up, I ran the engine harness that goes over the valve cover directly under the supercharger bypass valve arm. The arm anded up chafing through the harnes and shorting those two wires. I rerouted it further away from the bypass actuator after repairing the wires and no problems.
#2 - stuck bypass valve. My valve would stay open and not make any boost. Started after about three months. Fixed by applying machine oil to the actuator arm bearings once a week for three weeks, problem gone now.
#3 - randomly lost power to my fuel injectors. This one sucked since it left my car stranded three times. Problem ended up being a loose EFI fuse, don't know how it happened and completely unrelated to the supercharger. Fixed by using a tiny screwdriver to bend the prongs of the fuse holder closer together for better contact.
You will need to rewire the Blitz harness as well, FYI.
No time slip yet, I just got tuned with larger injectors last week.
See my post on fuel upgrades, I wouldn't run on the track on stock, the top end leans out to a dangerous level for prolonged periods
https://www.scionlife.com/forums/vie...742&highlight=
It won't make you more power but will allow for a safe 11.6 A/F ratio across the entire power band.
Hoping to get a time slip this Friday. No cooling issues, the Greddy S/C is self-contained for oil so there is no tapping into the engine oil supply so no heat dump into the engine. I did go with one step colder spark plugs to be on the safe side.
Only current issue is the supercharger belt squealing a bit on startup before the engine gets warm.
rain7905643
Jun 13, 2018 05:29 AM
BlingSlade
Sep 5, 2015 08:52 AM
