Fog Lights - bypassing headlight ON
Old Jul 14, 2007 | 05:42 AM
bigslimm's Avatar
Default Fog Lights - bypassing headlight ON
Just about to install oem fogs. I want to bypass the headlight 'on' requirement, and link to the running lights instead. . I have always done that on other vehicles by simply connecting the live feed to the running lights, Is that possible with the XB prewired harness - without major surgery?
Old Jul 15, 2007 | 04:17 PM
bryman31's Avatar
id like to know as well, also can u wire them 2 stay on with the high beams?
Old Jul 20, 2007 | 02:09 PM
CamoTrav's Avatar
There was a thread about this....try searching OEM fog lights/rewiring OEM fog lghts.
Old Jul 20, 2007 | 02:58 PM
kewlbox's Avatar
I think you can remove the groung wire(black) from the switch and groung the switch, but i have not seen it done.
Old Jul 20, 2007 | 09:03 PM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
alright you got 2 choices. 1 if you want them on when the parking lights are on, and 1 if you want them on whenever but you have to manually turn them off. there is a "relay" way but because i do not know exactly how it works i wont go into it.
1) when you install them, instead of grounding them at a certain location, just ground them to the turn signals. this will allow them to go on when the running lights or headlights are on, but will go off otherwise.
2)if you want them on whenever like i do, just ground it anywhere. if you already have it installed, just cut the ground wire to the switch and attach it to another spot.
there is a relay if you are fancy that you can install that will make them go on when you want them but will go off when powers cut... but i cant do all that. look for that one later!
Old Jul 20, 2007 | 10:10 PM
dekthai's Avatar
https://www.scionlife.com/forums/vie...548&highlight=
Old Jul 23, 2007 | 03:42 AM
bigslimm's Avatar
Great info! Thanks guys.
scsteven
Jan 25, 2015 01:06 AM
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
umnitza
Dec 1, 2014 06:26 PM
