possible to bottom out?
Old Jul 17, 2007 | 08:49 PM
GQQSE13's Avatar
Default possible to bottom out?
ok so i was reading online the other day of requirements for HIN and DUB and they require 5 mods( no problem) with 2 mandatory being suspension and aftermarket rims. my only problem is, the 08's already sit lower than the 05-07's and the way my exhaust mid pipe is, im afraid if i even drop it like .99 (w/ the megan lowering springs) i will bottom out my exhaust all of the time and tear up the underbody. any body have any suggestions of what i can do for suspension or anything i can do to avoid this?
Old Jul 17, 2007 | 08:58 PM
Mr_Meaty's Avatar
Well, you won't have any problem if you drop it on megans, cause they are crap, and the rears actually sit higher then stock!!!
how is your midpipe hanging? does it not travel downt he center path?
I have the Injen axleback, and it hangs WAY low under the rear axle, but since it's right where the wheels are, I never scratch it.
Old Jul 17, 2007 | 11:12 PM
Tcguy85's Avatar
the 08 sits lower than the 05-07? since when?
Old Jul 18, 2007 | 01:59 AM
Luc1f3r's Avatar
dont forget that when you add your rims you will add height, assuming you go for a larger size then stock, so you have that height to play with also...
Old Jul 18, 2007 | 02:02 AM
theblue's Avatar
I didnt know that either...
The injen exhaust is low, it looks like it could rub, but im on a hotchkis drop and even then it doesnt.
Old Jul 18, 2007 | 02:06 AM
Tcguy85's Avatar
[quote="theblue"]
can anybody confirm this?
Old Jul 18, 2007 | 03:07 AM
Mr_Meaty's Avatar
Confirm what? I have the injen and I'm dropped on hotchkis. No rubbing.
Old Jul 18, 2007 | 03:30 AM
Tcguy85's Avatar
that the 08's sit lower stock.
Old Jul 18, 2007 | 03:33 AM
SquallLHeart's Avatar
it doesn't.... it's the same.
Old Jul 18, 2007 | 03:37 AM
Tcguy85's Avatar
thats what i thought.
Old Jul 18, 2007 | 03:49 AM
GQQSE13's Avatar
i thought the 08's sat lower, because at the lot when it got it it was sitting next to an 06 and 2-07's and it looked like it was sitting a lot lower, and i've got the drift spec exhaust and it the pipe looks like it hangs like in mr meaty's pic
Old Jul 18, 2007 | 03:54 AM
gcxandy's Avatar
maybe the 06 next to you had trd springs?
Old Jul 18, 2007 | 04:04 AM
theblue's Avatar
x2
Old Jul 18, 2007 | 05:04 AM
Mr_Meaty's Avatar
You mean, maybe the 08 you looked at had TRD springs on it, since it's the one you thought looked lower.
Old Jul 18, 2007 | 03:57 PM
GQQSE13's Avatar
nope. because im driving the 08 and i know it doesnt have trd springs. who knows maybe i just didnt look close enough. but anyways, if having a pipe that hangs a bit like in the pic above, will i have to worry about it bottoming out if i drop it an inch or so?
Old Jul 18, 2007 | 04:08 PM
Mr_Meaty's Avatar
Well, that elbow hang sunder the axle, so as long as you DON'T go over bumps at and angle with the back tires, you shoudl be OK, because it lifts up with the wheels.
But your saying your 08 sits way lower then the 07 it was next to, and you wanna lower it more?
do you have any pics of the side view of your car, so we can see the height of it?
Old Jul 18, 2007 | 07:25 PM
GQQSE13's Avatar
i can take some. only reason i was going to do a small drop was for the fact that HIN doesnt let you enter unless you have some sort of suspension upgrade along with aftermarket wheels.
Old Jul 27, 2007 | 07:58 PM
davedavetC's Avatar
get the hotchkis springs and call it a day with the drop, you wont bottom out, i have had them for 40k miles and it still rides like the first day i installed them (seriously). almost 2 years on them too.
Old Jul 27, 2007 | 08:37 PM
GQQSE13's Avatar
awesome, thanks for the advice, any idea how much they run to purchase/get installed?
Old Jul 27, 2007 | 09:25 PM
davedavetC's Avatar
150 for sprngs, and freee labor, do it yourself. its easy
scionsux
Sep 2, 2015 05:30 AM
umnitza
Sep 1, 2015 08:06 PM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
