Power Outlet.
Old Jul 23, 2007 | 10:22 PM
pmarlowe's Avatar
Default Power Outlet.
Hi all,
My power outlet is not working. does anyone out there knows what might be wrong with it? My friend checked the fuse but said its fine, so what could it be? If you guys cant tell eighter, how much would it cost to get it repaired?
Thanks!
Old Jul 23, 2007 | 10:34 PM
sddykstr's Avatar
First, which one, I'm assuming you mean the cig lighter. Second, have you done any mods that would mess with anything electrical. Third, which fuse did you check.
Old Jul 23, 2007 | 10:45 PM
pmarlowe's Avatar
yes the cig ligther.
I have not done any electrical mods (not that I know of)I bought my 06 rs2 with amps, I noticed the amp wiring when I was changing oil so if it doesnt normally come with amps then then It couldve undergone some electrical mods. Aside from that, IDK.
If im not mistaken, i think my friend checked the fuse under the side mirror automatic adjuster. And i think he said something like fuse 16 i think.
Old Jul 23, 2007 | 10:55 PM
theblue's Avatar
it should be under warranty
Old Jul 23, 2007 | 11:09 PM
Ace83's Avatar
Ronin Scion
Make sure you checked the right fuse, or it wouldnt be bad f you check all the fuse. If its not the fuse then should be the wiring then..
Old Jul 23, 2007 | 11:13 PM
sddykstr's Avatar
Yeah check the fuses again, I doubt it's faulty wiring. I though it was an 18 anyway.
Old Jul 23, 2007 | 11:14 PM
pmarlowe's Avatar
Will do, thanks guys! ll get back if I still cant figure it out!
Old Jul 24, 2007 | 12:54 AM
VeeDubbx's Avatar
along with the fuses under the dashboard near the pedals, there is also a glass fuse in the center console near the cig lighter. i had the same problem as you are having now, and i went crazy searching for fuses and i couldn't find a burnt out one. i took it into the dealership and had it fixed under warranty. apparently we have fuses near the cig lighter, which i couldn't find, because it was hidden in massive amounts of electrical tape. if you don't want to mess with it, take it to the dealership. although it is a pretty easy fix.
Old Jul 24, 2007 | 01:25 AM
crabbyman's Avatar
OhioScions
...maybe the easiest thing to check that has yet to be mentioned...check to make sure the power wiring is plugged into the socket!
If someone put amp/subs in your car previously, it ias also very likely they had another headunit. If that is the case..they had to take the console area off, which requires unplugging the lighter socket for the easiest access to that whole area.
Old Jul 24, 2007 | 01:27 AM
VeeDubbx's Avatar
try that first^^! lol
ScionLife Editor
Jun 17, 2015 05:22 PM
Dbonehead6
May 28, 2015 12:15 AM
ScionLife Editor
Feb 25, 2015 04:40 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
