short shifter help...
Old Jul 26, 2007 | 03:00 PM
bronxblaza117's Avatar
tC squad
Default short shifter help...
ok just got my Creative Compacts Short Shifter and not quite what some parts are.
heres a pic
what are the four circle purple things in the packaging? whats its purpose? where does it go?
Old Jul 26, 2007 | 03:03 PM
ack154's Avatar
They go under the shifter cage to replace the squishy rubber bushings that are OEM. Helps to give your shifts a more solid feel. Definitely worth it and only take a few minutes more to install.
Old Jul 26, 2007 | 03:59 PM
engifineer's Avatar
They also should raise the cage to allow for the moved pivot ball on the short shifter.
Old Jul 26, 2007 | 05:35 PM
tC squad
ok i installed it. throws are so short. i find it a little rougher to switch gears though
Old Jul 26, 2007 | 05:37 PM
ack154's Avatar
It will usually feel a bit tighter for a while. I installed two of these shifters and both did the same thing. I still love mine though.
Old Jul 26, 2007 | 06:01 PM
Sleep3r's Avatar
dont worry you get used to it, maybe you should get some cable bushings also
Old Jul 28, 2007 | 01:10 AM
Deathwish238's Avatar
Well the shifter is shorter so you need to use a bit more force to shift. The cage bushings are nice, but what's awesome are the cable bushings
Old Jul 28, 2007 | 07:59 PM
tC squad
what do cable bushings do?
Old Jul 28, 2007 | 08:02 PM
engifineer's Avatar
They remove the dampening in the shift cable connection. So you end up with crisper shifts.
Old Jul 29, 2007 | 12:19 AM
Whenever you're about to shift into gear you can feel that you have to overcome a bit of a squishy area. That's due to the stock rubber bushings. Nice cable bushings are made of a solid material that don't squish...either you shift into gear or you don't
Old Jul 29, 2007 | 02:54 AM
Tcguy85's Avatar
yea, you should get used to the added stiffness very quickly. and the shifter cable bushings are a good idea as well. they are cheap, easy to install and make the shifts feel more solid.
Old Jul 29, 2007 | 04:47 PM
tC-JDM's Avatar
Is installing the short shifter hard??
Is the Ark short shifter good?
Are these short shifters shorter than the TRD one??
Old Jul 29, 2007 | 04:53 PM
SquallLHeart's Avatar
not really.
if you like it.
most yes.
Old Jul 29, 2007 | 08:25 PM
engifineer's Avatar
Short shifter install is a breeze. Some say they had a hard time with the press washer, but it really isnt hard at all to take off. 30 -45 minute install tops.
I stand behind the doctorisotope short shift kit. His stuff is quality and his prices beat everyone else last I checked.
Old Jul 29, 2007 | 08:56 PM
HaYnSktC's Avatar
^x2 i bought mine from doc i
it was my first time installing a STS and it was pretty straight forward esp if your reading off the DIYs on here
Old Jul 30, 2007 | 02:33 AM
It was my first "big" install on a car. The only trouble I had was getting the stupid cup off the shifter. Everything else was pretty straightfoward...with the exception of one clip...that was a _____. Nothing was difficult though..
Old Jul 31, 2007 | 03:00 AM
tC-JDM's Avatar
iight cool thxs guys
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
